Question about Refrigerators
The ice maker constantly making ice
The ice maker keeps going even though i have the handle lifted up, in the off position
  • 56 Answers
The icemaker is bad and needs to be replaced
Posted on Jun 02, 2010
The Ice maker is not making ice. The water is on is there a reset button?
No Reset call the manafacture or go the Store where you bought it and get an Exchange sound like its defective
Mar 06, 2017 | Refrigerators
I have a FrigidaireGallery Model FRS22XGCD. My freezer is NOT MAKING ICE. I do have and ice makers arm in the right position. Door water and ice does work. Do you have any ideas for me?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Ok, I am going to give you a series of things to check.
1.) Reach into the back of your ice maker. You have a fill cup and a full tube. Are they filled with ice? If so you have a frozen fill tube. You must remove the ice maker and with a hair dryer clear the tube.
To remove the ice maker:
On the left hand side there are two screws on top - loosen them. On the bottom there is one screw - remove it. There is a conduit connector in the rear - squeeze the tabs to release. Now, lift the ice maker up and pull away from the wall. If the ice maker does not lift out, loosen the top screws a little more.
2.) reach into your ice maker mold (tray) are their any ice cubes jamming the unit? Clear and lift your lever arm up and then down.
3.) Were you getting small ice cubes? And then no ice cubes? This could be a ice maker solenoid valve problem.
This component cost $165.00. You can get It for about 40% less on the internet. Part number 215197400. Purchase locally, Cost $55.00.
4.) You will need a multi-meter to check the solenoid valve. Unplug the unit. remove the bottom cover. You have a duel solenoid valve assembly. On the right bottom is your solenoid assembly. The plastic tubing running up the wall is for your ice maker. With a multi-meter set to the lowest Ohms, disconnect the two contacts on the ice maker solenoid. On the solenoid, use your meter leads on each contact. You should get a reading of '0'. if it is good. Anything other than '0' is bad.
5.) Within your ice maker you may have a bad thermostat.
This
This component is $62.00.
If your ice maker solenoid valve is good, rather than try to repair your ice maker, you can purchase a ice maker locally for $110.00, or go on line and purchase one for $45.00.
Your ice maker part number is FRS22XGCD0
Dec 04, 2014 | Refrigerators
Our ice maker keeps making ice even when the bin is full. LRSC 26945TT MODEL
I cant id the model #. Does the I/M have a bail arm or is it optical. If it has an arm lift it to the upmost position. It should stay there and keep the ice from harvesting. If it does not you Might need a new I/M.
Apr 14, 2011 | Refrigerators
Leak on the ice maker water supply
Good day,
The house water supply is connected to a dual water valve on the bottom rear of the machine. It splits there going to the ice maker and water in the door.
If the ice maker side is feeding water to the ice maker even though the ice maker is in the off position means the diaphragm in the valve is leaking and must be replaced. Very common problem.
Apr 11, 2010 | Refrigerators
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
Whirlpool Model ED25DQXXN side by side with ice maker running.
either lift the arm up and this should stop it or u can unhook the plug for the icemaker thats about ur only 2 ptions
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker makes even though Switch is OFF
replace ice maker. the cost of a service call.part's and labor would exceed the worth of the unit.
Nov 16, 2009 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Apr 29, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
