Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Kenmore upright freezer
I just bought a second hand upright freezer. The only information I have is that it is a kenmore(says on the door handle), the kind that the coils are inside as the shelves. What I need to know is 1)where do I find the product number so I can try to buy a key for it, also 2)I would like to know what exactly the temperature alarm is and 3)why when the freezer is set to 1(which I assume is the lowest setting) everything inside is still all frosty and while putting away groceries it melts all over the place! Thanks if anyone can help! There was no paper work with this freezer so I cannot even tell you how big it is or anything.
    Scholar:
  • 150 Answers
1)forget about the key you'll be disposing of this unit anyway
2)the alarm is to tell you that the unit is above ideal temp.
3)the unit isn't making temp due to refrigeration issue. if it isn't cold enough on 3 then 1 won't do it either.
Posted on Apr 23, 2008
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
Kenmore frostless freezer, Model 253-9280413. Food is properly frozen but both outside walls and the top are extremely hot to the touch, particularly the wall to the left of the door which is so hot you...
If your condenser grill is extremely dirty or air flow is not adequeate there will be heat transferance to the cabinet itself.
Highly recommend that you clean your condenser grill (the grill underneath the cabinet) and vacuum as much as you can then blow it out with an air compressor.
Jul 17, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Moving a Kenmore upright freezer
there would be a problem if you lay it down. it should be moved up right or max 45 degrees tilt only. oil in the compressor could go to the evaporator and clog it.
front handles could be remove only from the inside. you have to remove the plastic rack of the door and remove the insulation in order to see the bolt holding the handle.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Kenmore Freezers
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
209 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
