Question about GE JGS905SEKSS Stainless Steel Gas Kitchen Range
I have a GE gas range model JGS905SEK2SS and the bake, self -clean, oven light, delay start buttons on touch pad do not work. The other buttons do.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From whatyou have described it seems that you’ll have to replace the control panel/touchpad assembly to resolve this issue. Please do accept the solution if the issue is resolved orpost a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
  • Linda Corkhill Oct 31, 2011
    I have a gas slide in stainless steel range, GE model JGS905SEK2ss . Yesterday 10/30/2011 the glass top exploded, with glass and metal parts everywhere. I bought new Oct 2007, I paid well over $2000. I think it is beyond repair. Luckily no one was hurt. We are going to trash it.
My GE XL44 Self-Cleaning Gas oven heats up but is about 125-130 degrees cooler than what it is set for.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My ge gas range wont work on BAKE but everything else works model JGS905SEK2SS
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one.
Feb 09, 2010 | GE Profile JGB900 Gas Kitchen Range
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Bake display pad
contact ge and order a touch pad but tell them it melted during self clean and they just might give you one its 1-800-ge-cares ask for customer relations not cust service
Mar 28, 2008 | Hotpoint RGB745 Gas Kitchen Range
GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Jan 26, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Bake, auto clean, clear/off buttons not working
when pressed does the oven make any noise, beeping or clicking of some kind? if not then you need to replace your touch pad
Jan 28, 2007 | GE Profile JGBP79 Gas Kitchen Range
GE Spectra XL44
Sister, there is no pilot light on this model. Sounds like you have a bad ignitor, however the F7 code shows as a bad touch pad membrane. d7 must represent how many times this fault occured, although Im not finding anything that shows a d7 code. Try resetting the board by killing power to the range for about a minute. After turning the power back on press the COOKING TIME, DELAY START AND NUMBER 8 PADS ALL TOGETHER. The words test should be displayed. Now you are going to energize the bake circuit; press the bake and start, you should hear a click, this is the bake relay on the board. By holding the start button in you are energizing the ignitor (glow bar) in the oven. If you do not hear the click, suspect the control board. If you do hear the click and the ignitor is not glowing, you have a bad ignitor. Have someone with you to verify the ignitor is glowing when you are holding the start button in. To exit the test, just push CLEAR/OFF key pad. Catriver...post back
Oct 23, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
145 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
