Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
  • pgreen129 Jun 03, 2010
    Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button on the pump housing and rotate" - where exactly on the pump housing is the button?
    I already have the manual solution - I am looking for assistance with locating the exact location of the positioning button on the housing pump.
    Novelist:
  • 116 Answers
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Posted on Jun 02, 2010
    That is exactly what the manual says ... however where is the positioning button on the pump housing? For example - where is it in relationship to the discharge tube, left side, right side, etc...
  • dixie3087
    dixie3087 Apr 04, 2013
    lol i know i cant figure it out either... manual is non specific
  • 2,272 Answers
Your Hayward Power-Flo Matrix™ pump can be easily positioned for horizontal or vertical water discharge.
Step 1: Remove ALL plumbing attached to pump. Remove pump
from base (if applicable).
Step 2: Remove strainer housing.
􀂃 Disengage and lift off strainer cover.
􀂃 Remove strainer basket.
􀂃 Lift up on strainer ‘C’ clip and remove.
􀂃 Slide strainer housing forward and remove.
Step 3: Press positioning button located on pump housing and
(NOTE: Discharge port will only rotate ¼ turn.)
Step 4: Assemble the pump by following the above directions in the reverse manner.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 03, 2010
My Kindle only shows the books horizontally on the screen. When I turn the Kindle, the words do not move into the vertical position.
There is probably a rotation screen lock in the settings if this is on the screen will not rotate when the tablet is turned to the desired position the option should be in the settings menu need more info to determine where in the settings it is at
Jan 24, 2015 | Tablets & eReaders
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Which connection is the suction and which is the discharge for this model pump?
Inlet/Suction is always the port that is Horizontal.
Discharge/Pressure is normally Vertical.
So to answer your question specifically about this pump: The answers are above.
For others that may have a pump body that rotates, the discharge/outlet/pressure can/may also by choice, be horizontally exiting. But the horizontal port for discharge will now be "Perpindicular" to the motor vs. "Parallel" with the motor.
A "Horizontal" port Parallel with the motor will always be "Suction/Inlet"
May 02, 2014 | Hayward SP3007 10AZ Super II Pump 1Horse...
How to rotate a design that is to big vertical, will fit hortiz. on a singer future 6000.
Isn't your fabirc big enough to hoop it vertically, but stitch it
horizontally?
Do you own a Singer PSW? Easy to edit with this program.
Or you should be able to do in your Singer XL-6000 conversion tools.
Failing that you can rotate a design in the machine itself, simply on the machine by touching the hoop tab on the touch screen (second icon from the right) and then selecting the rotate icon (second from the top) then rotate the design?
Although I have known some designs to not rotate - due to the needle positions during the sewing and jumping process.
Hope some of these ideas are helpful to you.
Aug 19, 2013 | Sewing Machines
Hayward Pool Pump SP 1510 can I rotate the housing ?
No problem. Be sure toimages?q=tbn:and9gcsxyk8_ugvtk4dbhsw_znmzsxkyyed0iltvt4-u7eeckd3qkyu6 realign the pot to vertical.
Feb 18, 2013 | Pool & Spa
I am installing a 1592SP Power-Flo Matrix pump and I cannot seem to press the positioning button (it does not depress) to rotate the discharge port. I have taken off the strainer housing, but no matter...
I just went out and did mine. My button didn't depress at all at first. While trying to push the button in, jiggle the discharge both ways; the button will move in and the housing rotates very easily.
Gary
Aug 31, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
By mistake, when removing the water to replace it, I turned the cap and it came off. realizing my mistake I replaced the cap, pressed the button and tried to pull it straight out per the instructions on...
the directions state To change the filter you would 1.) remove the cartridge cap (counterclockwise to a vertical position) and pull the filter out through the base grille. Directions state there will be water in the cartridge so some spilling may occur. 2.) remove the cartridge cap by sliding it off the end of the old cartridge. The cap will slide to the left or right. Do not discard the cap. 3.) Take the new cartridge out of the package and remove protective cover from O-rings. 4.) Slide the cartridge cap onto the new cartridge. 5.) With cartridge cap in the vertical position, push the new filter cartridge into the base grille until it stops. Rotate the cartridge cap clockwise to a horizontal position. Its the first part of doing this thats a real pain but after you get by the first instructions the replacement becomes easy if you have any further questions message me back Thanks again Rick
Jun 14, 2011 | KitchenAid Superba Architect KSCS25INSS...
Hayward Matrix Power Flo
On the right side, usually opposite the discharge. You may need to use a butterknife of flat head to push it in; push in and turn.
Jun 27, 2009 | Hayward 1.5 Hp Northstar High Performance...
To read i have to turn my neck cause the all page is in the horizontal position instead of vertical
on the monitor is setting buttons find the one to rotate you might have a button that says menu start with that any more ? please feel free hope it helps
Dec 21, 2008 | Computers & Internet
Vertical positioning setting is frozen
lets see what i can do
sometimes under the screen edge either side or bottom they have the menu buttons these have become hard to find but there on your screen on one of the buttons the select should be de gaus (spell check) this sends a powerful power signal to monitor to reset its self some times its scary to watch but when it does that it should release the buttons parameters back to working state then use the buttons to set your parameters
the other thing is there is something stuck or broke in the button which was pushed a little harder then most
if this is the case
and you dont want to mess with monitor then take to computer tech. they will tear down and replace button backing sometimes the button backing points break off or disalign do to tomuch preasure on the button
i hope this helped you
May 25, 2008 | Acer AL1715 17" LCD Monitor
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
1,911 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
