Question about Samsung NC10-14GW Notebook
ASUS Eee PC will not boot after pressing the power button. I have already taken the battery out, tried ac power only. The indicator lights are on. The computer will not start. I just bought this in January and it was working fine this morning.
  • Deb Wilson Jun 03, 2010
    The resolution given before has left me with a sore finger and the Netbook in the same situation. The indicator lights still come on, but I don't hear or feel anything going on inside of the computer.
    The last resolution indicated trying another power supply - I have a battery pack and a power cord with a Asus Adapter. Which one would be the power supply?
    I have tried to hook up another display, and it also was black. The power lights are up and I can get the lights on my Seagate external drive to come up. However, I am not able to get the CD drive or the IR mouse to work in the USB ports. Really weird. I'm still trying to use the solution from my #1 answer.
    President:
  • 4,070 Answers
Hi! On this problem, it could be any hardware issue. It can be the hard drive or the motherboard itself. No display of anything? Hope to know more specially your last activity before the pc crashed. Thanks!
Posted on Jun 03, 2010
    I was in iTunes before I closed it down. Other than that it was just sitting there. I do however, have a tendency to leave it plugged in (with the battery pack) most of the time. That is why the #1 solution sounded like it could be correct.
  • dj_relly999
    dj_relly999 Jun 03, 2010
    Alright, If its a power supply issue then there should be no power coming in to the pc but theres still so you can disregard it. If you dont feel any activity inside then it can be a motherboard failure. When it is faulty it wont start at all. I do believe that your pc is still covered with warranty, I suggest that you take it in for service before the warranty voids.
  • 857 Answers
If you dont see any thing on the screen when you turn it on, in this scenario there are two possibilities either the mother board or the lcd screen may have a problem.
Follow these steps to find out the problem :
Turn on the laptop if you dont see any anything on the screen check if you have lights coming on or not, press the caps lock and the num lock key and see if you have any lights coming up, if you get the lights to come up then the motherboard is fine if not then there could be a possibility of mother board failure.
If you get lights to check if the screen is fine or not connect your laptop with an external monitor and then try to turn it on if you get the display on the external monitor it ,means that the lcd needs to be replaced.
apart from this try to re-seat the ram or swipe it and then try to turn it on. This is what you can do.
  • Jayant Jha Jun 03, 2010
    Try to re-seat the memory (RAM) and see if it works.
    Or there is a cable that connects the motherboard and the lcd screen try to re seat that. For this step you will have to open the laptop.
    Be careful while doing it.
  • 560 Answers
Hi. Please do this:
1. Remove the battery and power supply.
2. Press and hold the power button for 60secs. Repeat the step 5 times.
3. Insert the battery and power supply then turn it on.
If still no power, repeat the steps and increase the number of times you pressed and hold the power button.
You may have to do the steps several times. The purpose is to completely drain the electrical charges inside your unit.
Also, power adapter failure is common on Asus EEE PC. If your unit did not power up with the above steps, borrow a power supply and see if your unit will power up with diff power supply.
  • Liza Halbrook
    Liza Halbrook Jun 03, 2010
    Power supply = power adapter/charger
What to do with Asus Eee PC Seashell 1215N-PU27-BK-D525 blue power indicator light and power button, with flashing red light at battery charge indicator light? Computer will not come on.
try this
take out battery completely
plug into the ac adapter only
turn on computer
if that works, let it run for a few min then insert battery while still running
Jun 13, 2012 | ASUS Computers & Internet
Tried to power up my eee PC but only grey screen with logo comes. All keys freeze. Tried with and without battery, Tried plugged with power cord and without. Nothing worked.
Please remove the RAM, Hard disk and battery. press the power on button for 1 -2 minites. then insert only one RAM on another slot. Start laptop with AC power. Whether is it displaying the NO BOOT DEVICE or not. If display no boot device, please insert the Hard disk. then try..
Hope this helps to you.
If your problem not solved, please let me know...
Jun 18, 2011 | ASUS Eee PC 1001P Netbook
My ASUS eee pc gets stuck on the windows xp loading screen. i have tried starting it in safe mode, command prompt, last known configuration, pressing F8 and every time it gets to the loading screen and...
Welcome to Fixya.
I see that you're having boot issues, here are some other things that you can try :
  • Ensure that the computer is turned off
  • Unplug/disconnect all USB connections
  • Unplug the ac adapter cable
  • Carefully remove the battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter without the battery
  • Turn on the computer
If the above procedure works,then you may reconnect all devices once the computer is up and running. Otherwise, I am recommending a full operating system re install.
I hope this helps, Thanks for using Fixya.
May 04, 2011 | ASUS Eee PC 900 PC Notebook
Asus eee pc 1005hab will turn on but will not boot up. cannot get into bios vis f2, esc. just a frozen screen that says asus eee pc press f2 for bios. I have disconnected the battery many times, will not...
I have an Asus Eee pc 2g surf. I inadvertently installed a bios 2008 upgrade and cannot provide a password and cannot get beyond this page. Assus techs cannot provide it without an invoice and I have none as it was a gift. Any solution? I have taken out the battery, pressed f2, shift f10 ( which gets me to a screen "Atheos Boot Agent Configuration Agent" but not sure how this will help)
Jan 19, 2011 | ASUS Eee PC 2G Surf Notebook
My asus eee pc 1005he is suddenly shut off and it never boot up again even i pull-off the battery and put directly the power supply on it. And also even the led indicator for wifi, battery, power and HDD...
Does it beep at you? Sounds like your PSU is pooped to be honest (unless you get beeps), I would take it to a repair shop and ask for a new power supply unit. Shouldn't set you back too much, don't get ripped off!
Jan 06, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Blue power cord light is on, but computer does not power up or charge battery.
you can try the following:
  • Remove the battery and connect just the AC adapter and try to boot up. If it works then install the battery, if not
  • Remove the battery and AC and press the Power button for 30 sec
  • Under the netbook, ( when turned upside down) on the right-side near the windows key sticker you will see small hole use a pin to press this button. This will reset your HW.
First 2 solutions worked for me. I had issue with my battery calibration. After leaving it 24h on the AC all back to normal.
Hope it helps
Oct 04, 2010 | ASUS Eee PC 1000H Laptop
ASUS Eee PC running Ubuntu will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are...
Hi! Please check the motherboard for blown or corroded capacitors. If the capacitors are faulty it can result to a sudden reset or no boot at all. YOu can determine a blown capacitor if it has a whitish powder on the top or theres a leak on the top. Once replaced you'll be good. Hope this helps and have a good one!
Jun 02, 2010 | ASUS Eee PC 900 PC Notebook
Asus eee 900ah Plugged in a charger and battery is full. Now wont boot up. Any ideas?
I am not sure what the exact issue happened to ypur computer, if you are not able to turn on the computer then remove the battery and AC adapter from the laptop, not press and hold the power button for 20 sec( No batteery and Adapter), now connect the power cable back to laptop and then try to turn on the computer, still not able to turn on the computer then you consult with local tech or with wantty
Nov 20, 2009 | ASUS Eee 900 Netbook
Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
Samsung NC10-14GW Notebook Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
