Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I am starting an above the ground pool with a salt water system
I am starting an above the ground pool and I added a salt water system I have added more then the required amount of salt but I continue to get a low salt error reading How much salt should I add?
    Problem Solver:
  • 8 Answers
25 pounds per 1,000 gallons or 3 kg per 1,000 liters of water.
Posted on Jun 16, 2010
I have an Intex Ultra frame 18x48 with the salt water system, I haven't added salt in a while and keep getting a high salt alert and I add water frequently because of the evaporation (which is well water)....
When water evaporates, it leaves the salt behind. Depending on your well water, it may also already contain salt - adding yet more salt to your pool each time you top up...
Perhaps try emptying your pool (all or partially) & starting again - don't think the old trick of sticking a potato into an over-salted soup to absorb the excess (& removing it before serving, of course) will work on a pool!
Aug 06, 2013 | Intex Automatic Salt Water System for ...
My water is cloudy and says low salt. I added 120 lbs and it still beeps low salt. I have a CS8111 saltwater system & filter combo. It is on an above ground pool 24' X 52".
Check the electrolytic cell!!! You will get a low salt alarm if cell has calcium or sodium build up.. If it does, soak, flush and clean with vinegar.. Also, make sure you run the pump only, no chlorinator for 24 hrs to properly disolve the salt you just put in....
Aug 05, 2011 | Intex Automatic Salt Water System for ...
Where do i add salt to my intex automatic salt water system
Ad salt right in the pool water. Filter and brush around to disolve. Do not try to generate chlorine for 12 hours or so.
Make sure your salt content is as close to 3000ppm as possible
Jun 16, 2011 | Intex Automatic Salt Water System for ...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
I'm thinking about getting a above ground pool. Can I use the pump that comes with the pool to for salt water? And what is the routine for salt water maintance and start up?
What kind of filter comes with the pool?
If your using an intex pump don't waste your time. They do not pump enough.
If you are getting a sand filter then by all means get a salt system
Start up is simple ad x amount pounds of salt determined by the volume in gallons of your pool then filter only for 24 hours then you can start generating chlorine.
Just remember just because you use a salt system does not mean you do not need chemicals you will still need to use a stabilizer and keep track of ph also a good non foaming algaecide and crystal clear solution should be used
here is a manual for salt set up click on the top pump and look at around pg 15 this will give you salt to gallons ratio for pounds of salt needed
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 24, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
326 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
