Question about Dometic RM2620 Refrigerator
Gas shuts off after 30 seconds
While trying to use the fridge on gas, the fridge lights but won't stay lit. It's as if the gas supply cuts off
  • 4,793 Answers
First try fitting a new thermocouple,its the short 1"stick that keeps the pilot lit....
Posted on Jun 03, 2010
Atwood motorhome furnace won't stay lit
I would say this is your electronic ignition system but it sounds like it is not getting gas. This is why they do a 3 time try and shut off. Check you supply line right down to the regulator. Hose could have got partially kinked along the line as well.
Jan 31, 2013 | Heating & Cooling
We have a Dometic 3way fridge, the gas stayes lit only as long as I hold the button.
It appears that you have a bad thermocouple. This senses the heat and should allow the gas valve to stay open after the flame has been lit for approximately 30 seconds. By pushing the button you are manually opening the valve. Check to make sure the thermocouple is resting in the flame and is getting the proper heat.
Jan 21, 2013 | Dometic Refrigerators
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
We can't get our Dometic fridge to light when it's turned to gas. Model number 2453. It works on AC and DC but just won't light at all on gas. The gas will light but won't stay lit in the...
If you are lighting the pilot corectly and waiting for the thermo couple to warm up and then setting it to on, then the thermo couple is probably bad. Good luck!
Jun 27, 2011 | Refrigerators
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 02, 2010 | Teledyne Laars Laars Lx Pool Heater /...
Maytag LDG7400 gas dryer does not stay lit long enough to heat the drum. Can see flame turn on for about 10 seconds then back off for 20 to 30 seconds. Continues cycle of on and off until end of time....
Light sensors detect when burners are lit. If they become blocked with lint, dust, etc., they will not detect the flame and, for safety purposes, automatically shut off the gas flow.
Dust and lint are a dryer's worst enemy. Be sure that all sensing devices (particularly optical sensors) are clear of dust and lint so that light can pass unobstructed into the lens.
If they sensors are all clean, they might be defective. Something is erroneously telling your dryer's control that the burners are not lit and thus the gas supply is shut down.
Jan 01, 2010 | Maytag Dryers
Why won't my roper gas range (FGS337KQ) stay lit? The oven will light for 30 seconds and then shut off. Ignition is working.
you may have air in you gas lines make sure to hold pilot setting down for about 30 sec then light
Oct 30, 2009 | Roper FGS337 Gas Kitchen Range
Will not stay lit
The pilot sequence is designed to run for 45 seconds. It could be that the thermocouple is not triggering the cycle once the pilot is lit. I am having the same problem and intend to replace the thermocouple and then give it another go. The fridge works fine on electric but stopped working on gas last week.
Jun 29, 2009 | Dometic RM2852 Refrigerator
Flame goes out after 5 seconds
the thermocupple is a small tube that when heated shrinks to let gas flow if it is no good gas will not flow change the thermocupple thank you for useing fixya please rate me
Feb 24, 2009 | Dryers
Dometic RM2620 Refrigerator Logo
501 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
