Question about Frigidaire GLEQ642A Electric Dryer
Frigidaire FEQ332 dryer: I (stupidly) removed the 3 center screws from the inside rear of the drum (in a vain attempt to clean lint from the back) and now I can't get them back in. The dryer is a tight closet (with no easy way of accessing the back) - are the screws essential to the working of the dryer? If so, how do I get them back on without getting the dryer out of the closet (its stacked on a washing machine - so not easy to remove). Thanks for any advice (I'm such an idiot!).
  • CrisVan Jun 03, 2010
    it looks like the barrel has slipped a couple of inches - in order to realign the screw holes, I need somehow to raise the barrel - how do I get access to the space beneath the barrel?
  • 56 Answers
Well first turn the power off without those screws there is a chance you can arc the drum out agianst the element second you have to get at least one screw back in then rotate the drum slowly to line up the other holes do not run without the screws can cause some major damage
Posted on Jun 02, 2010
Testimonial: "Swift and helpful response - many thanks!"
  • stephen hughes Jun 04, 2010
    you cannt without taking the unit apart if you remove the lid you can grab the back of the barrel and lift up but you might want to get some help unless you have long flexable arms that can reach inside
The drum on dryer is off balance & making lots of noise can i fix it quick
its probably not the drum it is the bearing in the rear, easy fix if you know how, open the top remove the screws holing the front on, plus a little yellow plastic piece on the top center, remove the front, take out the 3 screws located in the back center of the drum then follow the instructions that come with the new part for bearing replacement
Aug 11, 2009 | Frigidaire Dryers
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
May 23, 2009 | Frigidaire FDE647RF Dryer
Adjust motor/heating elem to put screws back - Kenmore Dryer 417?
pull them away from the wall and see if you have an access panel in the rear of the dryer. If you do remove it and undo the belt so that you can freely sway the drum in either direction. it may re-align the holes for you to replace the screws if not you'll have to open the dryer possibly by prying the top up and undoind the screws that hold the front panel to the cabinet. from there you should be able to move the drum about to get the scres back in but f you do get it opened take the time to clean it out. Make sure you undo door switch wires before removing front panel.
Apr 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Inside dryer silver flaking off
If you need a new drum. Follow the instructions below.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Mar 07, 2009 | LG DLE2514 Electric Dryer
Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Jan 01, 2009 | Frigidaire Dryers
Drum noise
Dryer Drum Repair
Dryer Drum Repair
Aug 13, 2008 | LG DLE2514 Electric Dryer
Heater Element Housing
actually you probably blew element ..pop top up at corners with puty knife to release clips lift top remove 1 screw each side remove any wires to front panel ..panel will lift off clips from rear remove panel left bottom reach in and remove belt from idler/motor pulley note the belt routing first from front remove the yellow block lift up on rear of drum and pull drum out elemnt behind drum ..engineer who designed that element needs to do a few of those in a tight laundry room for about a month
May 05, 2008 | Frigidaire GLER642A Electric Dryer
LG Dryer cracked drum on Model DLE5977W
Dryer Drum Repair
Dryer Drum Repair
Apr 28, 2008 | Dryers
Electric Frigidaire Dryer Model GLER341AS1
there are two tabs that hold the top cover on,they are a couple inches in from each side.push in and lift lid. inside front panel are two screws, remove them then pull front cover out and lift it up of tabs on bottom.once you get the cover off remove belt,the you will be able to see your mess. heating element mounts to back panel.there is a heat sheild that mountws to the back of the drum.then you lift the drum up and put three screws in the drum to the pivot plate on the back panel.
Apr 21, 2008 | Frigidaire GLER341A Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
140 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
