Dynex 4-Port Ethernet Broadband Router (DX-E402) Logo
Posted on Jun 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Verizon modem to dynex router to hook up sprint airave.. and nothing is working I did all the set up but cant type in ip address with no internet.. HELP!
Alex Howard
Level 3:
  • Master 484 Answers
  • Posted on Jun 02, 2010
Alex Howard
Master
Level 3:
Answers
484
Questions
Helped
124120
Points
1243
Have you tried typing in 192.168.0.1? Or 192,168.1.1?
If so, what happens when you do? One of those addresses should take you to the configuration screen for your router, at which point you should be able to configure your router and go from there.
-a.
I have just bought a Dynex [DX-E402] router and i'm trying to connect my laptop and pc to the same internet through it but its not picking up any internet access. If i connect my pc directly from my...
The modem has likely assigned it's IP address to the MAC address of the PC.
We need it to assign an IP address to the WAN port MAC address of the router!
When you hook up the router, the modem is no longer sending data to the correct MAC address.
Unplug the power to both the modem and the router.
Power up the router FIRST, and wait for it to complete it's initialization.
Once the lights have settled down on the router, power up the modem.
Wait for it to fully initialize.
NOW turn on your PC or laptop, and everything should be working just fine.
If not, post a reply or add a comment to this post, and I will try to further assist you.
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE...
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
We got a new modem but the tech did not hook up the router and when we do it the internet doesnt work. We are using ethernet cables and nothing is wireless. How do i fix this?
Hi there, make sure that your router and your modem have different IP address. because if they are both the same there is a possbility to have IP conflict in your setup.
thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I'm trying isolate parts of my network and I need to place a Dynex 4-port router right after my modem and then plug my office lynksys router into that. (At present, the linksys is plugged into the modem...
Modem <--> Dynex <--> your computer should work.
Connect:
Modem <--> Dynex <--> Linksys router <--> your computer.
Turn off all the above devices.
Turn the modem on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Dynex on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Linksys on, and wait for its lights to "settle" down to a repeatable pattern.
Turn your computer on, and wait for its lights to "settle" down to a repeatable pattern.
On your computer, click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
The Linksys router should have given you an IP-address for your computer, and the IP-address for the "gateway" (namely the Linksys router).
Start your web-browser.
Type http://192.168.0.1 (or http://192.168.1.1) to connect to the web-interface "inside" the router.
Access the 'WAN' settings-page on the router, to see what IP-address the Dynex router has given to the Linksys router, and what "gateway" IP-address that the Dynex router has offered to the Linksys router.
It might be best to change the range of "dynamic" IP-addresses that one of the routers hands out, e.g., '192.168.123.100' to '192.168.123.200' for the Dynex router, so that both routers don't try to hand-out IP-addresses in the *SAME* range.
How do i set upa dynex dx-e402 i have a verizon dsl and an xp based computer
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually
set up correctly.
I do have a guide for that.
Once that is done you should consider giving out proper IP addresses
Big business does this for security and reliability and it is no different for home users except maybe easier
Read the guide for router and modem first and if any of it may apply to you then try and do it.
The second part deals with IP addresses and this may well help you
I have a selection of computers laptops servers at home on a small network
It is quite some time since I last had to do any sort of system wide shutdown
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Take note of the DEFAULT GATEWAY
Now do the same thing with your ROUTER
If that too has the same IP as your modem in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
2helpful
2answers
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
1helpful
Dynex dx-ehb4 will not change ip addresses
I am not familiar with that router so I will provide general knowledge and you can apply it to fix your problem.
It sounds like your cable modem is willing to supply a single IP address. This can and should be connected to the WAN port of your router. The problem is that the router is not assigning IP addresses to the equipment that is connected to its LAN ports. Instead, it allows that single cable modem IP to be assigned to connection #1 and everybody else gets nothing. Get the computer working through it, connect to the router as per the owners manual and turn on NAT or DHCP, whichever it offers. Reboot the computer and connect xbox and you should be good. This was probably not an issue with DSL because your DSL modem would supply up to about 10 IP addresses and they also passed through the router.
Dynex 4 port ethernet router
When the TCP/IP is set to dynamic or "Obtain Automatically", the default gateway is supposed to blank. The default gateway address of your network is actually the router's IP address.
What is the IP address that you get when you performed step 3?
Dynext router
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
4helpful
4answers
Dynex e401 router
Don't buy dynex routers of any kind!!!
Dynex intentionally has it set up to browse the web through their 3rd party systems (rather than directly through your own IP) when you use their routers. So once you enter all of your IP account information with them, you start browsing the web through their own 3rd party server systems so that they can run background web content in order to boost page views for their affiliates! This slows down your web activity, especially if you using multiple computers with one of their routers! Why send users through dynex 3rd party servers to browse the web? Because the more page views that are coming from multiple IP address, the more SPONSORS they can get to support their websites!
Dynex routers are a SCAM in order to get people to browse the web through their own 3rd party servers!!! Why is it that when I type in a web address (after hooking up their router, and attempting to set it up) that instead of saying “waiting for google.com” or “transferring data from google.com” it says “transferring data from http://192.168.1.1/” which is the dynex website! Why would it allow me to only lookup their website (to configure settings) but then block all other web content until setting have been configured??? Think about this, their website isn't already on your computer, it has to be accessed through the internet in order to load onto one's computer. That means the internet is already working through their router, they are just restricting access to other sites until you configure your settings to go through their 3rd party servers for all of your web browsing!
I have used many routers before, and NEVER have I been asked to configure settings on some website before being able to use the product! Most REAL routers don't require any setup or configuration of any type. As long as you properly install everything, and your computers are internet / ethernet ready then you should be good to go. Usually if a router requires some sort of setup online where you are blocked access to all other internet sites until you configure through the manufacturers' site then it's most likely a scam product! A product that serves as a front for getting massive page views (for their sites and affiliates) in order to get lots of sponsorship for having high web traffic!
If you are in the market for real ethernet routers then you should buy d-link, or linksys products instead of dynex! In my opinion, dynex is total JUNK! BUYER BEWARE!!! Don't waste your money on this!!!
Top Dynex Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
