Question about Roper RAS8244KQ Top Load Washer
How do I replace the lid switch
Washer does not spin or empty after wash cycle. The top doesn't look like it is he kind to raise back against the wall. I need to know how to get the top part up or lifted to replace the lid switch
  • 23 Answers
The way you get the top off is reach on the back side of the right and left side and you will feel or see a screw that is in a slot. unscrew the screws and then pull the control panel forward and up. you will see the 3 wire connection in the middle and that is the door switch wires. you will also see two gold clips when you take those off you will be able to take the cabnit and under the cabnit you just have two unscrew a 5/16 screw which holds the ground wire on. and that should be it.
Posted on Jun 03, 2010
  • 56 Answers
There should be two screws on the back of the head the plactic piece on the left and right side that hold it down once you undo the screws the head should come up then there is two brass looking clips depending on how old you put your screwdriver in thoughs and unhook them from the cabinet from ther you simple lean the cabinet forward and you have easy access to the switch
Posted on Jun 02, 2010
Washer it will not change from wash to spin
If this is a top loading washer it is likely the lid switch.
If the tab has broken on the lid the switch will not actuate. The switch can be replaced by an experienced repairman. The power must be removed before attempting any repairs.
The washer will not drain or go into the spin cycle with the lid raised or defective switch.
Check that the tab is not broken!
Oct 03, 2016 | Washing Machines
Admiral washer will not spin but does agitate.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely -if it's frozen or stiff- replace it.
a.- It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
a.1. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
a.2. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.- It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
b.1. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.2 The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
b.3 A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
b.4 The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
b.5 The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
b.6 The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
b.7 The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
c.- It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Additional details in Admiral: Washer Use and Care Guide (PDF Format)
Check it and keep us updated.
Oct 10, 2011 | Admiral AW22 Top Load Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
My roper washing machine will not empy out or spin. It agitates alright but stops when it comes to emptying the water and going into the spin cycle.
Replace the lid switch with this part.
Dec 27, 2010 | Roper RAS8445KQ Top Load Washer
Won't start when cover closed
your lid safety switch is shot,you need to remove 2 side control panel covers that pop off,then remove 2 screws that are under here, then control panel will separate from top to let you unplug lid switch connection to the control panel,then open the top cover by popping clips inward on the 2 front corners with a putty knife or something flat like this between the top and front covers,then raise top up and lean back against the wall there you can access this switch to replace it,this switch is designed to shut off unit if lid is raised during spin cycle for your safety
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer fills with water and just sets there spin cycle works
The timer is failed in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Kenmore 110.92575110 top load washing machine will fill and agita
This problem is normally attributed to a defective lid switch. If the lid switch is loose or broken the lid is not detected as being closed and the washer will not operate beyond the beginning of the wash cycle. You need to check the switch to see if it has become loose, or if the lid strike as been broken off. NOTE: If your washer is equipped with one, it will be a small plastic piece located on the lid and activates the lid switch when the lid is closed. Get back to me and let me know what you find. I can assist you in locating parts and provide instructions on how to replace the switch if necessary.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Roper RAS8244KQ Top Load Washer Logo
197 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
