Question about Hotpoint RGB745 Gas Kitchen Range
HOW TO REPLACE THE IGNITER FOR THE LOWER BURNER. MODEL RGB745. THANKS
  • 56 Answers
Usally the lower plate in the oven lifts up from the back and comes out there might be two screws to remove this. if not pull the drawer out and go threw the bottom
Posted on Jun 02, 2010
Hotpoint gas range rgb745 electric igniter not working
Make sure igniter is getting power before you replace it. Also check the switch that feeds the igniter.
For parts go to attached. Search Over 2 1 Million Appliance Parts
Oct 07, 2015 | Hotpoint RGB745 Gas Kitchen Range
My hotpoint. Has burner activity. The electronic oven will not light, makes no sound when the temp knob is depressed, nor with a match under the burner will it light. Makes no sound through trying each...
Ok
Is your igniter glowing when oven turned on.Look for bright orange glow near burner.If yes ,and no ignition,then igniter is weak and needs replacing.No glow at all,then a voltage test at the igniter needs to be done to see if it might be thermostat problem. Very common for igniters to go.Most likely cause.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
Front burner will not light the igniter is good it woks in the other burner and i put a good igniter in the burner and it will not work
What happens when you use a long match or a long butane lighter? Does the gas ignite?
Since the igniter is working in another burner, then either the gas isn't getting to the burner (sealed burner blocked), the spark is being blocked or the electrical connection to the igniter is bad.
Take apart the burner and clean the openings. Make sure that the hole in the part that slides over the electrode is clear (use a needle or the wire from a twist-tie). See page 28 of the manual. (available online from http://www.geappliances.com/service_and_support/literature/ . Enter the model and click submit). Make sure you replace the parts of the burner correctly.
My range also has an orifice at each burner that could be blocked. Turn off the gas before investigating this. Look at the instructions for converting the range from NG to LP - this should be attached to the back of the range near the regulator. This will tell you how to access the orifice and what size wrench to use. I believe my range uses 10 mm.
To check the wiring, you may need to lift the cook top. Often the top is secured with clips on the left and right sides.
I hope this helps.
Jun 25, 2011 | Hotpoint RGB745 Gas Kitchen Range
The lower burner does nor ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Hotpoint RGB745 Gas Kitchen Range
Only the two left spark ignitors work. I switch the wires from the left side to the right side and the ignitors worked. The wires from the right side I hooked to the left side and they did not work....
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 09, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
New igniter, still won't work
Turn on oven. Ignitor should begin to glow. (if no glow after 30 seconds or so, check to make sure you have 120 volts to ignitor) Observe amperage draw using a clamp on amp meter. When amperage reaches 3.2 to 3.6 (for square syle ignitors) the oven safety valve should open, releasing gas and lighting the burner when the gas hits the red hot ignitor. For broiler, just substitute the word broiler for oven. Old ignitors get " weak " and may not draw enough amperage to allow safety valve to open. Also, voltage will affect the amperage draw, as lower voltage = lower amp draw.
Nov 06, 2008 | Hotpoint RGB745 Gas Kitchen Range
Lower heating is not working
Replace the igniter even if it "appears" to be working. Bright red isnt hot enough. It has to be bright white. Goodluck...
Dec 17, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
551 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
