Question about Sony Cyber-Shot DSC-W7 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera--battery problem
My camera eates more battery, Fully charged 2500 mAh batteries last 10-15 minutes max. . or 15 to 20 snaps max after that it starts showing battery indicator as half.
I need the software that I can install in mycomputer.i lose the CD
Posted on Apr 13, 2009
  • mmmga Apr 13, 2009
    Problem Solver:
  • 4 Answers
To solve this open the camera and remove the battery chamber (be careful with the cable that joins the chamber with the main board because it is very fragile). Once you have the battery chamber clean all the contacts with a contact cleaner. By all the contacts I mean, the 4 contacts for the batteries and the two contacts (male and female) that join the main board and de chamber. Be careful when you apply the contact cleaner to the main board contact bacause it is a liquid and might harm your lens if it reaches it. I have made this with my camera and worked awesome.
Posted on Jan 01, 2009
My camera wont power nor charge?
Have your battery replace with NiMH batteries (1.2 V) with 2500 mAh. I charged up some of these and my camera works fine.
Jan 11, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
I Use a fully charged(more than 14 hrs charged) New Sanyo battery 2700 mAH Ni MH rechargeable on my Sony Cyber Shot DSC-W5 Digital camera, when the power is on the battery display shown fully...
may be batteries you brought are old try with normal ( not rechargeble ) batteries. it would not last long but you can take atleast 30 to 50 photos. if it works it means new batteries are faulty.this type of problem i never saw in camera.use SANYO harmolattice HR-3UQ batteries.
Jun 22, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
My DSC-W7 was working fine the other day, it was just sitting on my counter one day and it wont come back on? any suggestions?
Check these:
  • Batteries are fully charged
  • Take the batteries out completely and reinsert them after a while
  • Try new batteries
If none of the above work, take the camera to a local electronist or Sony dealer for repairs.
Apr 09, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
DSC-W12: the batteries last only a few minutes before they're drained. Camera draining batteries very quickly.
If its a Lithium ion battery(similar to a mobile phone battery) then open battery compartment, clean battery contact points and try again after recharging the battery. If the camera uses AA batteries look for the current ratings on the side of the battery, generally digicams need batteries with more than 1200 mAh (I use a 2000 mAh for my Canon SX110 IS digicam). This current rating may vary for different manufacturers.
Jul 25, 2009 | Sony Cyber-Shot DSC-W12 Digital Camera
How long time I churge "SONY NP-BG1 Battery
The first charge you should let it go overnight, so it has a good solid charge. After that it depends on the mAH of the battery, the higher the number, like 1400, it should take about 3 hours. There should be a led light on the charger, its red when charging and turns green when completed. The chargers have a voltage regulator on them, so that you can't over charge a battery.
Jan 08, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Battery Problem
If you have used this camera more than three months Try changing the battery. Before using fully charge the battery. Let the battery consumed in your camera fully then you charge again. Otherwise the battery life will reduce. Try this option before trying any other option.
Best Regards
Rafique
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Extremely short battery life
do you use alkeline batteries? if yes then they would end in 20-25 shots. Instead, use rechargable batteries of 2500 mah which will last long, very long. On my Cybershot H1, they give aproximate 350 shots with single recharge.
Go for Sony Original Batteries or Uniross brand also works fine.
2300 mah/ 2500 Mah any will work.. :-)
Nov 25, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Power shuts when in camera mode
The user manual would not be of much help. Please try to clean the battery contacts inside the camera. Please use the new fully charged NI-MH accu batteries preferably 2500 maH capacity. If this measures do not provide a cure please contact the nearest Authorized Sony Service. If you need more info please advice.
Apr 10, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
Sep 08, 2005 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera Logo
214 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
