Question about ASUS Eee PC 900 PC Notebook
ASUS Eee PC running Ubuntu will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are on. The computer will not start.
    President:
  • 4,070 Answers
Hi! Please check the motherboard for blown or corroded capacitors. If the capacitors are faulty it can result to a sudden reset or no boot at all. YOu can determine a blown capacitor if it has a whitish powder on the top or theres a leak on the top. Once replaced you'll be good. Hope this helps and have a good one!
Posted on Jun 02, 2010
Asus Eee 1005HA hangs on boot
This works for my Asus Eee PC
1. Shut down and remove the battery.
2. Press the power button 10 times, next 1 minute pressing down.
3. Remove the memory and at the motherboard you'll see a clrrst (clear reset cmos..)
4. Short these 2 tiny pads by placing a tiny screw driver for 5 seconds, plug the power adapter and turn-on the switch, next wait at least for 3 seconds. Remove the power adapter.
5. Place back the battery and turn-on. You'll see the same screen (Logo of Asus) then patiently wait for at least 10 minutes or more. That's it.Good luck.
Feb 16, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Tried to power up my eee PC but only grey screen with logo comes. All keys freeze. Tried with and without battery, Tried plugged with power cord and without. Nothing worked.
Please remove the RAM, Hard disk and battery. press the power on button for 1 -2 minites. then insert only one RAM on another slot. Start laptop with AC power. Whether is it displaying the NO BOOT DEVICE or not. If display no boot device, please insert the Hard disk. then try..
Hope this helps to you.
If your problem not solved, please let me know...
Jun 18, 2011 | ASUS Eee PC 1001P Netbook
My ASUS eee pc gets stuck on the windows xp loading screen. i have tried starting it in safe mode, command prompt, last known configuration, pressing F8 and every time it gets to the loading screen and...
Welcome to Fixya.
I see that you're having boot issues, here are some other things that you can try :
  • Ensure that the computer is turned off
  • Unplug/disconnect all USB connections
  • Unplug the ac adapter cable
  • Carefully remove the battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter without the battery
  • Turn on the computer
If the above procedure works,then you may reconnect all devices once the computer is up and running. Otherwise, I am recommending a full operating system re install.
I hope this helps, Thanks for using Fixya.
May 04, 2011 | ASUS Eee PC 900 PC Notebook
Asus eee pc 1005hab will turn on but will not boot up. cannot get into bios vis f2, esc. just a frozen screen that says asus eee pc press f2 for bios. I have disconnected the battery many times, will not...
I have an Asus Eee pc 2g surf. I inadvertently installed a bios 2008 upgrade and cannot provide a password and cannot get beyond this page. Assus techs cannot provide it without an invoice and I have none as it was a gift. Any solution? I have taken out the battery, pressed f2, shift f10 ( which gets me to a screen "Atheos Boot Agent Configuration Agent" but not sure how this will help)
Jan 19, 2011 | ASUS Eee PC 2G Surf Notebook
Blue power cord light is on, but computer does not power up or charge battery.
you can try the following:
  • Remove the battery and connect just the AC adapter and try to boot up. If it works then install the battery, if not
  • Remove the battery and AC and press the Power button for 30 sec
  • Under the netbook, ( when turned upside down) on the right-side near the windows key sticker you will see small hole use a pin to press this button. This will reset your HW.
First 2 solutions worked for me. I had issue with my battery calibration. After leaving it 24h on the AC all back to normal.
Hope it helps
Oct 04, 2010 | ASUS Eee PC 1000H Laptop
Asus eeepc 900a linux mouse buttons no longer workrunning ubuntu 9.04 nbr on the original 4g ssd
corrupt boot procedure is a classic example of this symptom,Recommend re-install,restore and reboot without pressing any otherwise unwanted keys
Mar 08, 2010 | ASUS Eee PC 900 Notebook
Asus eee 900ah Plugged in a charger and battery is full. Now wont boot up. Any ideas?
I am not sure what the exact issue happened to ypur computer, if you are not able to turn on the computer then remove the battery and AC adapter from the laptop, not press and hold the power button for 20 sec( No batteery and Adapter), now connect the power cable back to laptop and then try to turn on the computer, still not able to turn on the computer then you consult with local tech or with wantty
Nov 20, 2009 | ASUS Eee 900 Netbook
Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
Black screen will not boot up
try removing the battery and just run off power cord this may be a bad battery seen it before
Apr 15, 2009 | ASUS Eee PC 1000H Laptop
ASUS Eee PC 900  PC Notebook Logo
163 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
