Question about Garmin Approach G3 Handheld GPS Receiver
When i turn on gps message reads no gps signal if you continue search results may not be based on your current position. ok or cancel
  • 20 Answers
Your GPS MUST have line of sight to the satellites.
Are you in the garage or is it a very cloudy day.
Also tall buildings can block some sat view the GPS must have at least 3-4 to work most link to 7-9 all the time. GPS do not work well in metro areas too many tall buildings.
Posted on Jun 03, 2010
How do I program my lowrance to locate reefs if I have the lat log reference?
You can go to your GPS page and zoom out and then using your cursor pad and move your cursor so it is in the general area of your coordinates. Start zooming in andifferent as you do the the lat, long readings on your screen will become more precise. Continue to adjust your cursor position so the coordinates match up with known position you have. Continue until the cursor position on screen and your known coordinates match.
Push "ENTER" twice. Your way point will be saved at the current position of the cursor.
OR
Push your cursor pad to bring up your crosshairs on the GPS screen. Save that waypoint, then go in and edit the coordinates to match your location data and save it. The waypoint you created will move to the new coordinates.
Aug 10, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
No gps signal with tomtom
Solution for No GPS Signal
To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays gray and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal
  • The GPS signal was lost sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after traveling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full color and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster.
Flight mode
On devices with built-in GPRS connectivity, flight mode also disables your device’s GPS reception.
To switch flight mode off, tap Flight mode in the preferences menu and then select Restore connections.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Reset your device
Reset your TomTom device. Click here to learn how to reset your device.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Feb 01, 2010 | Tomtom ONE GPS Receiver
My tom tom has lost gps help! all of a sudden half way through a journey my tom tom lost all GPS signal and wont pick up anything? is there anything i can do to get it back?
here are some tips on what to do ,To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays grey and one of the following messages is shown in the bottom right corner of the Driving View:
  • Your TomTom device has been relocated without using it (e.g. after travelling by plane or train).
Once your TomTom device has located your current position, the Driving View is shown in full colour and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster. Flight mode
Clear View
Reset your device
Aug 28, 2009 | Tomtom ONE GPS Receiver
I have a Tom Tom GPS and all of a sudden it says searching for satellite signal but never picks one up. Any suggestions?
  • Waiting for a valid GPS signal…
  • The GPS signal was lost … sec ago
Clear View
Make sure battery is fully charged before use
Reset your device
Jul 24, 2009 | Tomtom XL 330 Car GPS Receiver
Can't get satellite signal for my GPS.
Once your TomTom device has located your current position, theDriving View is shown in full colour and shows your position on the map.
Regards.
Jan 04, 2009 | Tomtom GO 730 Car GPS Receiver
Triton 1500 GPS, I can't get any green bars to receive position.
You may have a few problems. First the GPS signal is controlled by a special GPS+ANT card in the 1500 and it may be defective. As for dates, etc. this could be caused by an other firmware update or a bad software file. Go to the Jungle Ghost Repair Center at www.jungleghost.com they have parts for the Triton units.
Dec 29, 2008 | Magellan Triton 1500 GPS Receiver
Continual "waiting for gps " message
the message should also read no mnsa data first... if these units are not in continual use,they get corrupt for some reason. all you can do is hope the gps fix will work itself out,otherwisw buy a new unit.
Dec 26, 2008 | Navman ICN510 GPS Receiver
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
TOM TOM 910 no gps signal.
If TomTom is stating there's is "No GPS Device" then you don't have TomTom configured properly. You need to set TomTom to use "Other Wired GPS", select 4800 or 9600 bps and set to COM4. Once this is done it should detect the GPS and it will either show you your current position or it will say no valid GPS signal.
Use GPSTest application (search on google or on this website) to test your GPS. It will automatically scan your device, detect the GPS and give you a lock on your current position.
Nov 29, 2007 | Tomtom GO 910 GPS Receiver
No signal
Remove the Antenna while in the upright position, clean connection and replace. Set the GPS current position. Then initialize the GPS. Select Yes and leave the unit alone for 20 minutes. Do not press anything else. The initialization runs in the background. make sure you have a clean line of sight to the sky. Then turn the unit off and back on. You should be OK.
Oct 26, 2007 | Magellan RoadMate 700 GPS Receiver
Garmin Approach G3 Handheld GPS Receiver Logo
729 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
