Question about Minn Kota Boating
Minnkota MXT series trolling motor foot pedal won't turn right. I now have 3 of these pedals with the same issue. Is there a sensor or some other repair that can be done. otherwise I need to buy a new pedal.
  • 8 Answers
SOURCE: motor won't run
Look at the red indicator arrow when you hit the foot pedal. If it lights up, the motor should run. If not, inspect the splices under the top cover on the shaft. They will stop the motor if corroded or burnt.
Posted on Nov 28, 2008
Editor925
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
Posted on Apr 30, 2009
  • 10 Answers
SOURCE: somethings come loose in the head of the trolling
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 02, 2009
  • 3 Answers
SOURCE: Minn Kota power drive trolling motor will not
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    How do you reset remote for w75 wireless trolling motor
    Its very easy:
    Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
    IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
    back into the power source between activating each control device.
    1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
    2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
    simultaneously.
    May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
    On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
    You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
    Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    How do you operate the motor? I have no details as to how the motor operates. Its a minn kota trolling motor that mounts on the front of my boat. I need to know how to operate the foot peddle.
    The pedal has generally four functions:
    1) Forward and back on the pedal make the motor go left and right (push forward to turn the motor right, push back to turn it left)
    2) Momentary power - the little 'button' towards the top will engage the motor as long as you press down on it.
    3) Selector Swith - on the side of the foot pedeal there is a switch with the following settings Con - Off - Mom (Continuous - keeps the motor going all the time, Off - well it's off and Mom - will only go when you press the momentary button).
    4) Speed select - the knob on the left controlls how fast the motor goes.
    It takes some getting used to but offers tremendous control and hands free operation!
    Jun 25, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Foot pedal on Motorguide is out of time with steering...
    There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
    Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
    Motor won't run
    Sep 02, 2008 | Boating
    Boating Logo
    109 people viewed this question
    Top Minn Kota Boating Experts
    Colin Stickland
    Colin Stickland
    Andrew Taylor
    Andrew Taylor
    Phil Walker
    Phil Walker
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
