Question about Smith AO Pool Pump Motor
Installing a replacement pool pump and motor
I have a new A O Smith Century LASAR 115 volt Motor and need guidance on which connectors to wire to.
  • Smith Master
  • 1,368 Answers
There is a green screw and two other screws. green is ground and the others two are universal, it's not like a DC motor.
Posted on Feb 25, 2014
SOURCE: I HAVE A CENTURY LASAR POOL/SPA MOTOR W/ A HIGH
Faulty centrifugal switch, internal, faulty, temp sensor, internal, faulty start run capacitor (If used). bad brushes, (If any) Faulty Winding.
Posted on Feb 03, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: Hi I am replacing pool pump motor (O A Smith
In this case you are going to be better off consulting a electrician to help you with this issue. There are to many risk involved in getting someone to assist you over the internet with this. If someone tells you the wrong wire placement and you get hurt or pop the fuse in your house you are now looking at that much more work,
Posted on May 05, 2010
agent91
  • 2100 Answers
SOURCE: Pool pump 3/4 hp wiring
I think the lug with no screw is for 110 volt? Don't know, but your 2 wires in, black and red are both hot, each one to the lugs,line 1 and 2, the bare wire gets bolted on outside of the motor and jumped to another ground somewhere, and the white wire, goes to a lug marked B?,,, check that one. I went to the web site and they want you to know if you do it wrong, no guarantee, so check out the frame number, then look up your motor and go by the label.
http://www.pool1.com/motor.asp Hope this helps.
Posted on May 06, 2010
Testimonial: "Thank you this was all I needed was the link that you give me. It showed the wireing digramof the motor. Thanks Max B"
  • 760 Answers
SOURCE: S48A84A04 - AO Smith motor diagram - I am looking
Here is a great pdf file for AO Smith motors. This covers other types of motors too but does give a few views of the starting switch mechanism.
http://www.discountpoolzone.com/poolmotor/pump_motor_university.pdf
Posted on Oct 01, 2010
  • 372 Answers
SOURCE: Help! Just opened my pool and the pump/motor (which is only 2 years old) is very noisy. Sounds like it could be the bearings. Do call someone to the house, disconnect and take to a repair shop, ord
Disassemble the pump to the point where you can see the whole impeller. Then turn the power back on to verify that it is the bearings, and not trapped debris causing the noise. If it is the bearings the short answer is to replace the motor.
Bearing failure is usually related to a leak at the pump seal. This results from either a faulty seal installation, or the pump running excessively hot (from running w/o water).
When replacing the motor carefully examine the seal plate (where the seal is set) front and back for any cracks or deformity. If the new seal doesn't set exactly, it will leak.
Posted on Apr 04, 2013
How to replace seal on century lasar spa motor
split the motor from the wet end then take off the cover to the impeller remove screw for impeller backwards thread might have to hold the shaft on the back of the motor then unscrew the impeller regular threads separate the motor from the backing plate replace seals then reverse process
Jul 05, 2014 | AO Smith A O Smith Motors Century 1hp 115v...
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
A.o. smith f48g56a76 wiring diagram
loo kon side of motor for 115 volt wiring they normally come wired for 220 volt
Dec 02, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
My new AO Smith motor does not have an L1 IT has L2, L3, and L4 so how do I hook the wires?
There is a schematic on the motor itself to show you exactly how to hook it up. The main thing is knowing whether it's 115 volt or 230 volt connection. Good luck any questions hit me back up.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Apr 26, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
A.O smith pool pump tripping breaker
It you either have an impeller problem or capacitor problem on the motor. I would take the capacitor off and take it to a electronic or lexical shop to have them check it. It's only about 15 to 20 dollar pics if it's just your capacitor.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS YOU.
Apr 08, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
Apr 21, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Smith AO  Pool Pump Motor Logo
149 people viewed this question
Top Smith Pool & Spa Experts
Mike Squire
Jay Finke
Jay Finke
Bill Jordan
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
