Question about Asko 24 in. D3250 Built-in Dishwasher
I have a D3251 and the door won't close/latch....how do I solve this problem? Thank you
I just had this problem and it seemed to be fairly easy to fix. Some times when you open and close the door interrupting washing cycles, the latch will think it is already latched. Even though it will still close with pressure, it seems like it will pop back out on you. Here's the fix. If you open the door, you will see a white plastic accepting latch that can be flipped back into the fully open direction using a screwdriver. That seemed to do the trick.
Posted on Jun 20, 2010
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
1995 Voyager Front passenger door latch stuck - door won't close
insert blade of screwdriver behind cam like piece pull up on handle and push up on cam like piece this should reset the latch
Dec 10, 2012 | 1995 Plymouth Voyager
Back door won't close
take a philips screwdriver in between where the latch grabs the part of your car its is a circular area and release the latch at the same time pull down on the screwdriver and it will pull the latch back in the correct position to be able to agai n latch to the cars part of the latch to grab to
Dec 01, 2012 | 1994 Chevrolet Suburban
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
95 dodge caravan drivers door won't latch
often normal door latches will wear out causing the door latch to not activate the "full latch". The full latch ends up moving further up and into the latch. the solution is to replace the latch or have it rebuilt.
Aug 03, 2012 | 1995 Dodge Grand Caravan
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Door dosnt latch closed
My name is mike, thanks for directing your question to me. First of all Your latch needs to be replaced. If it is not working proper it also triggers that machine door is not closed so of course it wont start. Here is a site link that might help you some as well.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
If this helped you, please rate my free help and some nice words would be nice. Thanks Mike.
Also here is my personal Market Place site for other areas of my expertize.
http://beta.fixya.com/users/mc1beanThanks Mike
Oct 31, 2011 | Washing Machines
1994 Pontiac Sunbird 3.0 L, V 6. I got home. I opened the car door. I closed the car door and IT WILL NOT SHUT. Is it a simple fix, as in, unhook the battery to reset the locking system? Then I tried to...
heres what you do open the door and theres a latch that connects to the hinge when shut the door take a flat head screwdriver flip the latch up so can close the door this should fix the problem if not pull positive battery cable off let sit 2 minutes reset computer doing this but still have to flip up the clasp itself
Sep 24, 2010 | 1994 Pontiac Sunbird
What does F9 mean? Won't allow me to use the oven
F9 -It is a Door latch fault code
Check door latch components.The stove is not detecting a proper door close.Or else there might be some metal blocking the door from closing.It should solve itself in few hours else you might have to replace the door latch system.Good luck with the machine.Please do post comments.Also do rate the solution.Thank you in advance.
Apr 10, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Cassette doors
Bent or broken door latching part. Take in for service
Apr 29, 2008 | Audio Players & Recorders
Asko 24 in. D3250 Built-in Dishwasher Logo
352 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
