Question about John Deere Garden
Tractor will not start
When i turn the key to start the engine, it justs clicks rapidly but nothing else. It appears its not getting to the starter. A large number of wires go to a box and they go to alot of other components. This box vibrates when the starter is turned to the start position. But the starter does not move or even feel like its getting juice.
    Novelist:
  • 146 Answers
Rapid clicking, or buzzing from the relay box when you try to start is usually a symptom of a battery that is discharged. Try jumping the battery from your car or another piece of equipment. If that works, you just need to charge the battery with a battery charger.
It could also be a corroded or loose battery connection - take them off (negative post first), clean them, grease them a bit with vaseline, and tighten them up again (put negative back on last). If still not fixed, it's probably the starter, which will cost a bit more to fix. Good luck! If you found this helpful, please rate my answer, thanks.
Posted on Jun 04, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Car doesnt want to start. all lights come on when in the on position however when I turn it to start nothing happens it dont even try to turn over it just clicks 2002 hyundai xg350
The starting system consists of:
  • starter motor
  • starter switch, part of the ignition switch
  • starter motor solenoid relay switch
  • starter solenoid
  • starter drive
When you turn your key to start your engine, it just clicks, right? If so, more than likely this is due to a bad battery. Even though your battery may appear to be fully charged, it may have a dead cell, or worse. If you get a jump, does the vehicle start? If so, replace your battery.
Possible sources of the problem if the engine does not crank or the relay clicks:
  1. Battery
  2. Starter motor
  3. Starter motor relay
  4. Ignition switch
  5. Damaged fuse
  6. Anti-theft system
  7. Circuitry
Mar 16, 2011 | Hyundai XG350 Cars & Trucks
When I turn the key I get a rapide clicking sound
Check your ground wire for battery where it connects to your frame.
Also check/clean the connections where the positive wire goes to the starter solenoid. Any connection you run into from the battery, clean them off with a wire brush or sandpaper.
Starter Solenoid can also be failing/dead, these can be tested for free at most auto part stores if you remove them from the vehicle.
Jun 17, 2010 | 1998 Chevrolet C2500
Won't turn over when I try to start
Really clean your battery connectors, Make sure jumper cables are beefy or they will not allow enough power. If your starter clicks, it is either stuck engine, weak battery, dead solenoid connectors or dead armature inside the starter. In rare cases cable connections can come loose at the solenoid (A mechanic knows to take some solenoids apart and turn the connectors upside down to the uncorroded side.) Make sure your blade is not stuck, make sure your brake is in the correct position, make sure your engage levers and shift linkage are in the neutral start positions.
May 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
Jun 06, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Turn key and get a click
the started is probably jammed and needs to be unbolted and put starter bendix gear back in starting position turning over an engine too long on a jump start can cause this
Apr 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starter clicks rapidly, not cranking, no ignition
It almost sounds like you have a loose connection at the battery. If the connection is loose it can cause the starter to click as you have described. Also it could be the starter itself. If the starter is bad (locked up) it can make the clicking noise and not start the engine. If you can get to the starter, try to tap on it with a hammer while someone is trying to start the engine. I hope this helps.
Jan 03, 2009 | 2004 Pontiac Grand Prix
95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
Sep 16, 2008 | 1995 Ford F150 Styleside Regular Cab
1990 Buick Lesabre , 3.8 Won't start
Can I please have a bit more detailed description of exactly HOW it won't start does it not turn the engine over?
Does the egine turn over and just won't start?
Does the starter "click" or do nothing ?
Aug 16, 2008 | 1990 Buick LeSabre
Garden Logo
176 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
