Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
I have installed a Honeywell PRO TH3000 thermostat to my Zoneline AZ38H15DABM1. With the R and Rc terminals on the thermostat connected by jumper the zoneline runs @ 5 mintues. I see in the manual No common busing allowed. I need to know the exact wiring - the exact terminal to use for the different colored wires on the zomline and the exact terminal to usefor the differnt colored wires on the thermostat. Of course, they are marked and all wiortes are connected as the diagram says by color code. I'm assuming this zoneine is a 2 transformer model. So with the red terminals on the thermostat not connected by the jumper and the red wire in the right terminal on the thermstat as suggested nothing works. so What is the exact correct wiring for these two products to work together correctly???
  • redroosterma Jun 03, 2010
    i sent comment for clarification and was redirected to this accept page.
    President:
  • 1,902 Answers
Everything is wired right as long as the jumper is there. Put your unit is only a single transformer model and not a double. So that is where your issue is. I would as need to know the colors that you are using for the wiring. So if you can get that to me I can help you with a better wiring then what you have, but you are going to have to make sure that the T-Stat will work with a single phase unit.
Posted on Jun 03, 2010
    How do I determine if the T-stat is a single phase unit? With the jumper installed it will run for only a few minutes. I am using the wire colors according to diagram - only I have used the blue wire for the GH (high speed fan) on the Zoneline since there is only one green wire. So, in order, from Zoneline to T-stat the wires go red to red, Green (low fan) to green, Blue (hi fan) to O on the T-Stat (keeping the order) Black to black, Yellow to yellow, White to white, common to common. There is a brown wire left over not connected at either end.
  • Jeremy Reddick
    Jeremy Reddick Jun 03, 2010
    Wait I thinnk that I know your problem. What color did you use to hook up the common?
How do I wire a Honeywell thermostat
Can I start by saying I am not in anyway saying to do this alone it is dangerous but if u must follow each step start by being safe shut off the breakers good luck here to help
Step 1
Turn the air conditioning and heating unit off by flipping the appropriate circuit breaker. Test the unit to make sure it's off by turning your existing thermostat to the "On" position and seeing if it turns on. Wiring a Honeywell thermostat when the circuit breaker is on could cause you to blow the transformer that powers the HVAC unit Step 2
Connect the red wires to the thermostat RH, thermostat RC or thermostat R terminal. The thermostat RC terminal has a jumper wire between thermostat RH and thermostat RC. The thermostat R terminal operates both the heating and cooling units, and contains an internal jumper wire. Basically, your red wire on a Honeywell thermostat is the hot wire that run. Step 3
Run the green wire to the thermostat G terminal. The green wire controls the relay that operates the blower, and it controls the fan. Step 4
Control your air conditioning when you connect the yellow wire. It connects to the thermostat Y terminal Step 5
Hook the white wire to the thermostat W terminal to control the heating unit
Nov 20, 2014 | Heating & Cooling
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
There are four terminals on my mr. heater, R, G, W, C. And ont the programable honeywell thermostat there are 5 terminals, Y, G, Rh, Rc, W. Rh and Rc have a jumper between them, Which wires go to which...
Red goes to either Rh or Rc since there's a jumper there it doesn't make any difference. Look at the old thermostat and see where the Y,G, C, W and red were connected originally. Sometimes thermostat wire won't have the usual colors so you need to be observant to what colors are present.
Feb 28, 2013 | Heating & Cooling
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Aug 26, 2008 | Honeywell Programmable Thermostat Heater
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
373 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
