I have an issue where I have two workstations mapped to a shared folder with only 2 permissions. They have the exact same credentials and rights. One machine will let me map to it and works find. The other one will let me map to it but tells me I do not have permissions for the folder. It use to work fine and now this. George
  • 4,924 Answers
If you are talking about accessing folders over the default gateway(the router in this case) check the firewalll in the machine that can access the other but do not lets its contained to be accessed..When fire-walled and with nothing on share it says that you do not have permission ..even if you see the other machine ..try and disable the firewalls in both ..or change the properties in the files you need to share ..and practically check the share mode of the folders from the properties..I think that even fire-walled if you mark the folders as shared..it will be accessible for each others inside the default gateway (the workgroup ..in out case internal network)
and of course..there is always the issue with the computer that you made the settings from ..and its seen as the admin..of the router ..that one always will have rights over the units in the local network ..
Posted on Jun 02, 2010
Hi, I have two pc running with windows xp operating system. From User 1 i need to access user 2 windows folder and program files folder otherway around also but I can't how? Even if I shared windows folder...
First thing Windows XP Home Edition will give you numerous problems when sharing files, you should consider using windows XP Pro for that sort of operations.
Assuming you have Windows XP Pro installed in both computers:
1 - Create the same user on both computers ( same account name, same password ) blank passwords are not allow between file sharing as per windows xp group policy.
2 - Create a resource to share ( example: C:\)
3 - Disable simple file sharing
* go to control panel
* click on folder options
* click the VIEW tab
* unckeck the use sharing wizard
4 - Make sure that the user that will be used for authenticating between computers have the proper NTFS permissions and the proper access to the shared sources.
5 - Try to connect to the shared sources when asked for username and password type the credentials of the newly created user.
Now you should be able to connect to the shared sources both ways.
Oct 18, 2010 | Computers & Internet
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
Target folder not accessible.
Perform the steps mentioned in the below article.
http://support.microsoft.com/kb/810881
Also, try this:
CAUSE
This issue may occur if the folder that you cannot open was created on an NTFS file system volume by using a previous installation of Windows, and then installing Windows XP. This issue may occur although you enter the correct user name and password. This issue occurs because the security ID for the user has changed. Although you use the same user name and password, your security ID no longer matches the security ID of the owner of the folder that you cannot open.
For example, although you use the same user name and password, you may no longer have permission to open the folder after you complete the following steps:
1. Before you install Windows XP Professional, you change the actual location, or target location, of the My Documents folder to another volume.
2. You format the primary partition.
3. You install Windows XP Professional.
RESOLUTION
To resolve this issue, you must turn off Simple File Sharing, and then take ownership of the folder:
1. Turn off Simple File Sharing:
a. Click Start, and then click My Computer.
b. On the Tools menu, click Folder Options, and then click the View tab.
c. Under Advanced Settings, click to clear the Use simple file sharing (Recommended) check box, and then click OK.
2. Right-click the folder that you want to take ownership of, and then click Properties.
3. Click the Security tab, and then click OK on the Security message, if one appears.
4. Click Advanced, and then click the Owner tab.
In the Name list, click your user name, Administrator if you are logged in as Administrator, or click the Administrators group.
If you want to take ownership of the contents of that folder, click to select the Replace owner on subcontainers and objects check box.
6. Click OK.
You may receive the following error message, where Folder is the name of the folder that you want to take ownership of:
You do not have permission to read the contents of directory Folder. Do you want to replace the directory permissions with permissions granting you Full Control? All permissions will be replaced if you press Yes.
7. Click Yes.
Click OK, and then reapply the permissions and security settings that you want for the folder and the folder contents.
Also, try to create a folder in external Hard Drive and then try to back up the data.
Jun 25, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Windows Vista not accessing shared folders on network. It keeps asking to log onto network PC and keeps saying cannot log in when trying accounts on the network pc. Both PC's are on the same workgroup and...
This is a usuall problem when connecting Vista and XP, specially when your vista is a 64-bit and your XP is 32-bit. What you need to do is to manually map the folders on the vista by opening windows explorer and then clicking on Map network drive, you need to put in the exact folder location. Next thing is you need to add user not only activationg the allow access, you need to add the user on the shared folder, you are only using workgroups, unlike domain networks, you just have to give them permission.
Sep 05, 2009 | Computers & Internet
File sharing
it is possible
If you have multiple computers in your home and they are connected through a home network, you can share files among your computers. That means you no longer have to copy files to a floppy disk or USB flash drive to transfer them to another computer. Once you configure your computer to share files, you (or another user with the appropriate permissions) can, by using Windows Explorer, open them from other computers connected to the network, just like you’d open files that are stored on a single computer. You can also choose to have folders visible—but not modifiable—from other computers on the network.
To share files on your computer with other computers on a network, you need to:
Share a folder on your computer. This will make all of the files in the folder available to all the computers on your network (you can’t share individual files).
Set up user accounts on your computer for everyone who needs to connect to your shared folder. If any of the accounts are Limited User accounts (unless an account is a Computer Administrator account, it is a Limited User account), follow the steps in Set permissions for files and folders to enable them to open your files.
To access shared files that are on another computer on your network, you need to:
• Connect to the shared folder from other computers on the network. This procedure is described in Map a network drive.
Note: By default, file permissions only allow your user account and administrators on your local computer to open your files, regardless of whether a person is sitting at your keyboard or at another computer. It may help to keep these three things in mind when setting up file sharing:
• Files have user permission settings.
• Every computer has its own user database.
• Some accounts are administrator accounts and some aren’t.
Configure your computer to share files To share a folder on your computer so that files stored in the folder can be accessed from other computers on your home network
1.
Log on to your computer as an administrator. For more information, see Access the administrator account from the Welcome screen.
2.
Click Start, and then click My Documents.
68599-click-my-documents.gif 3.
Right-click the folder that you want to share, and then click Sharing and Security.
68599-click-sharing-and-security.gificotip.gif Tip: If you want to share your entire My Documents folder, open My Documents, and then click the Up button on the toolbar. You can then select the My Documents folder.
4.
If you see a message that reads, As a security measure, Windows has disabled remote access to this computer, click the Network Setup Wizard link. Then follow the instructions in How to set up your computer for home networking. On the File and printer sharing page of the Network Setup Wizard, be sure to select Turn on file and printer sharing. If you do not see this message, skip this step and go to step 5.
68599-click-network-setup-wizard.gif Note: If you do not see the Network Setup Wizard link or the Share this folder on the network check box, your computer probably has Simple File Sharing disabled. This is a common change made to computers used for business. In fact, it happens automatically when a computer joins an Active Directory domain. You should follow these instructions to share a folder instead.
5.
In the Properties dialog box, select the Share this folder on the network check box.
68599-click-share-this-folder.gif 6.
If you want to be able to edit your files from any computer on your network (instead of just being able to open them without saving any changes), select the Allow network users to change my files check box.
68599-click-allow-network-users-to-change-my-files.gif 7.
Click OK.
68599-click-ok.gif Windows Explorer will show a hand holding the folder icon, indicating that the folder is now shared.
To connect to the shared folder from another computer, follow the steps described in How to map a network drive.
Note: By default, only you and other people with an administrator account on the computer sharing the folder will be able to open your files. To limit access of specific users with an administrator account on the computer sharing the folder, read How to set permissions for files and folders.
Aug 14, 2008 | Microsoft Windows XP Professional
Access Dened on Local networked drive
if u r using NTFS you should go to the shared folder-->right click it-->click sharing and security -->go to security tab-->add the your user and give it full permission.
you may need to be logged with same user name on the other Pc that has the mapped drive .
Jul 07, 2008 | Microsoft Windows XP Professional
Error 5
hi
check the permission of the share and also you may have to create a user just for sharing
This is a permission issue. If the net view command fails with a "System error 5 has occurred. Access is denied." message, 1) make sure you are logged on using an account that has permission to view the shares on the remote computer.
2) Need to cache credential: logon the same username and password on both computers or use net net use \\computername /user:username command.
3) Make sure the Netlogon service is running
the second question : it is a spyware
check this link in regards to clean t
Feb 13, 2008 | Microsoft Windows 2000 Professional for PC
Can't access my share folders
Drive management show only safely remove usb drive.
When u use mionet software it map the share to a drive letter. If u create folder or files on that drive u dont have permission to chance those files or folders on \\mybookworld.
Solution, dont use mionet software.
Nov 12, 2007 | Western Digital 500GB My Book World...
Having problem installing office 2007 on Microsoft office Vista
Hi Noglao, I have experienced similar problem with my Office 2007 installation, I believe its a problem with the CD itself, there might be a scratch or something that is blocking this file from being read. Maybe even a manufacture error since I had the exact same problem with the same file. In the end I had to copy the disk to my hard drive and I moved it to a share folder on my file server. I mapped this share folder to a root(z:) on my workstation. I ran it from there and it worked just fine. If you don't have a server or can't map a folder for some reason I suggest trying another installation CD, or copy the files to your computer, burn a new CD and try it again with that CD. Good luck Daniel
Aug 16, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
