Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Where is the housing and bulb located for sony kdf42we655 I have the replacement housing and new bulb
  • 597 Answers
Look in manual...The lamp door should be visable
Posted on Jun 03, 2010
New Sony Brava KDL32EX713U. On first switching on no response from the screen. Is this likely to be repairable or is it a new unit?
Very likely the thermo sensor right above the bulb. If this EVER over heats you need to replace it (only $15)...You need to be able to locate it because it's very small but directly above the bulb housing itself :)
Please rate if this helped :)
Mar 14, 2011 | Sony Televison & Video
How do I replace lamp in my Sony-KDF42WE655 model.
There are 2 thumb screws at each lower side. Fully loosen those thumb screws then pry the panel out. You will see the lamp covered by a plastic panel. You will see 4 screws covered by gray plastic. Remove the screws and you will see another thumb screw in it. Just loosen the thumb screw also then remove the covered plastic. You will now see the bulb. You need to remove the 2 screws then you can now remove the bulb. Just do backwards to put everything back again.
Jan 01, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
Where is the bulb loacated on kdf42we655
Bulb/ lamp is located under front lower panel that need to be removed. There are two thumb screws on lower corners of front screen if you see tv from rear, remove these screws and take off lower front panel, you will see lamp cover, remove it to see lamp.
Lamp replacement procedure is written in user manual with exploded views. Click Sony Support to download free copy of user manual of KDF-42WE655 for more details.
Jun 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bright galaxy like dots on KDF42WE655 why?
Light engine is bad. Contact Sony they have been replacing these due to a class action law suit.
Mar 26, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I removed the housing and bulb and the bulb looks
Even though the bulb looks okay, it still might be bad. Chances are you need a new lamp. However there is a possibility that the issue is with the power supply for the lamp. But I would say spend the dough on a new lamp first.
Nov 02, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony (KDF42WE655). Always have a video 7 label on the screen
Try these:
  1. Press MENU on the remote control
  2. Select Settings
  3. Highlight Setup
  4. Select Label Video Inputs
  5. Select Video 7
  6. Select None if available or
  7. Leave the label blank
Aug 23, 2009 | Televison & Video
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony 42'' kdf42we655 no picture , lamp light flashing
If the lamp light is flashing, yes you need a new lamp. Be sure to buy an original Sony lamp as the replacement lamps are garbage and are not worth the discount. Please rate this solution. Thanks!
Nov 15, 2008 | Sony KDF-42WE655 Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
