Question about LG LDF6920 24 in. Built-in Dishwasher
Have trouble code LE?
I turn on the washer and within 8 to 10 minutes this code appears and it stops?
  • 56 Answers
Wash motor is bad or the harness from the upper control to the motor has shorted out if you take the front panel off and look at the harness it runs from the top of the door doen often the wires fix themselfs into the coating on the door and melt agianst it that dishwasher can get pretty hot but it causes the wires to short out often if you pull them out of the black tar it will simple break in your hand make sure power is off to unit you can put a **** connector ther if this is your probablem but it is recommend you replace the harness and the door panel
Posted on Jun 02, 2010
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
LE appears on top loading washer wt5170hv
The LE error or fault code is to indicate that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Sep 11, 2014 | LG WT5101HV 4.5. CU. FT. ULTRA CAPACITY...
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
What does code LE mean? The washer stops and LE appears
Code LE signals an overload to the motor. Wait 30 minutes and restart the cycle. If the code is not released, you need to call a service technician.
Jan 07, 2011 | LG WM2487H Front Load Washer
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Le code appears during normal cycle
LG recommends unplugging the washer for 15 - 20
minutes to reset the microprocessor.
The most common cause for the LE error code is over-sudsing in the machine from using regular detergent instead of a high efficiency detergent. The HE detergents are designed for lower suds levels and enhanced cleaning performance in front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. LG recommends loading the washer until the clothes in the drum are no more than three-fourths of the way up the window of the door. This will allow them sufficient room for tumbling.
http://tclaundryrepair.com/
Feb 26, 2009 | LG WM1814CW Front Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Lg washer code le
LE= That is a water inlet error
Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes
Check you water supply lines and make sure the screens on the valves are not clogged
Jul 09, 2008 | LG Washing Machines
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
LG LDF6920 24 in. Built-in Dishwasher Logo
129 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
