How to re-set-up my belkin N+ wireless router
  • 12,061 Answers
Ok, this is quite an easy task, what you need to do, is using a browser is you Login to the Router, using Login & Password, and then you enter your ISP details, again your user name and password. Then if you want, you can setup the security settings, and generate a WAP/WEP KEY. If you do not know the old existing login & password, then you can "Reset" your router, there is a small hole in the rear, using a straightened paper clip, push the button, with the power Off. This will reset the router back to factory spec's. But again, this is all found in the easy to use manual.
The best thing to do, is use the manual I have provided below. In this manual, you will find step by step details of exactly how to do it all.
en-us-support.belkin.com/app/answers/detail/a_id/125
Posted on Jun 03, 2010
SOURCE: Configuring Belkin Wireless Router
You choose a wireless router so you need to install in some freequency. You can choose the freequency by the list like 2.4 G.Hz ect. then just select the link & fix threre working ares / type. Avoid the command prompt. use bessic settings your user manuel help you further.
Posted on Feb 13, 2008
  • 256 Answers
SOURCE: Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Posted on Jun 11, 2009
  • 38 Answers
SOURCE: setting up a belkin n wireless router. How do I
You have to go into the setup for the router. Most default to the 192.168.1.1 IP address. You would type that address into your internet browser and hit enter. Then you will be asked for a name and password. If you have your belkin manual it will tell you the default name and password. Once in the settings you can change the password. You can also turn off SSID broadcasting, enable the highest level of security that your particular router supports in conjunction with your computer and enable MAC authentication. If you enable MAC authentication you have to type in the MAC address for each device you wish to have access to the router.
Posted on Nov 07, 2009
teckman45
  • 52 Answers
SOURCE: Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to www.bioticaindia.com and download a win 7 driver there. They show a 48% success rate.
Posted on Dec 13, 2009
govinda123
  • 2263 Answers
SOURCE: Lost Belkin Wireless G Router F5D7230-4
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Jan 13, 2010
I need to configure a N600 Belkin router. How?
Reset the Belkin router -
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 21, 2013 | Belkin Play N600 Wireless Dual Band Router...
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
How do I adjust the MTU settings for Belkin router
Contact Belkin for Care at 1-800-585-2494 Toll Free
Apr 29, 2009 | Belkin (F5D7633UK4A) Wireless Router
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
Jun 26, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
