Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have a GE Profile side-by-side, model # TFH30PR. I had mold in the ice dispenser chute. I cleaned it superficially but would like to know how to take the dispenser apart so I can clean it thoroughly. Can you help me with this? Thank you in advance for any assistance you can provide.
aasc
  • 1606 Answers
SOURCE: I have a GE profile Artica side by side. I am
The ice door flap is not closing completely, or, your using a lot of crushed ice .
Posted on Jul 19, 2009
aasc
  • 1606 Answers
SOURCE: GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
woodchuck789
  • 4066 Answers
SOURCE: Our GE Monogram Icemaker will only dispense crushed ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Posted on Aug 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
Sea Breeze
  • 4654 Answers
SOURCE: Refriger not cold but freezer is cold
Your defrost timer is inside the fresh food compartment and behind and inside the control panel. Part number WR09X0489. I will show you a photo location. Be right back, Sea Breeze
Posted on Apr 08, 2010
Our GE Profile side by side refrigerator is making hollow ice cubes and the water dispenser comes on by itself sporadically for about 3 seconds a few times a day. Over night it filled a whole glass of...
Hello. Hollow cubes is caused when there is not enough water going into the ice cube molds. That said, since you have too much water going into the water dispenser I would suspect that the valve needs to be cleaned or possibly replaced. Joe
Mar 27, 2010 | GE Profile¿ Arctica® Energy...
Ge profile artica ice dispenser and chute frosing.
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice chute cloggs with solid chunk of ice over time
Have you had high humidity over the last few months where you live?
This could be normal under those conditions.
BUT.....make sure the door is closing FULLY at the ice dispenser outlet.
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
