Question about DISH Network IR Remote Control
Dish network control not working on 2nd. tv
I have a dual receiver that controls the living room and the bedroom but the remote will not control 2nd tv
  • Chad Yeomans Aug 28, 2013
    Does the LG tv in the bedroom need to be linked or something to the reciever ? I know can watch the same show as the living room , but second remote does nothing in the bedroom .
    Scholar:
  • 37 Answers
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Posted on Jul 06, 2010
2nd remote paired to two fans.
close the door and turn off power to that room and then try again
May 24, 2015 | Televison & Video
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
My dish network remote for tv 1 is not working. My remote control of tv2 is controlling both my bedroom tv and living room tv. what can be the problem?
Hi this is Phillip Chang from DISH Network. Sorry to hear you have been having that remote issue, let's get that fixed. The problem may in fact be that your receiver is currently in Single Mode when you want it to be in Dual mode. Check that the amber "Mode" light on the front panel of your DISH receiver is lit on the right hand side (indicated by two overlapping squares), if it's not then we want to press the mode button, located behind the door on the right side facing the receiver. Most times this fixes it.
Let me know if you have any follow up questions.
Dec 08, 2010 | DISH Network IR Remote Control
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Aug 15, 2009 | DISH Network IR Remote Control
Lost remote
On the front of the receiver press and hold the mode button, when you have it in single mode choose system setup and then shared view.use the arrow keys to highlight "enable" on the shared view and then "done" to save changes, you can then use the one remote to watch the same thing on both TV's, until you either find or replace the problem remote.
May 13, 2009 | DISH Network IR Remote Control
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
DISH Network IR Remote Control Logo
7,666 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
