Question about Vehicle Parts & Accessories
Siren came on while driving the car and could not 1997 saturn sl
Siren came on while driving the car and could not get it off, had to cut wires. what is the solution to the siren problem
  • 171 Answers
Pay attention at the time that this is happening because I guess your alarm is in anti-car jack mode so if the car is in running mode and them suddenly you open any door. This function will activate after usually 30 sec. or less. the only way to fix this is deactivating this function at the program mode of your allarm.
Posted on Jun 05, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I own a 1997 saturn sl and one of my main fuel lines from the tank has a hole in it. What is the easiest way to replace it myself or should I take it to the dealer?
Not a good idea to play around with leaking fuel in the confines under a car. If the hole is localised the garage may just cut it and fit a compression join at the break or if the hole is symptomatic of corrosion along the length of the fuel line it is probably expedient to replace the whole section.
Aug 20, 2010 | 1997 Saturn SL
97 Saturn SL with a 1.9 DOHC exhaust valve problem
It may be that the seat or the margin on the valve was cut wrong.....
Feb 15, 2010 | 1997 Saturn SL
1997 Saturn turns on and drives well. When we hit
look for vaccum leaks and also if you put it in neutral before stepping on brake will it still stall?
Nov 06, 2009 | 1997 Saturn SL
1997 Saturn SL-2 DOHC cracked head?
not really your head holds alot of pressure any temp. fix will just break
Sep 26, 2009 | 1997 Saturn SL
Wiring diagram
1997 Saturn SL 1.9L MFI SOHC 4cyl
1991-98 Starting, Charging, Fuel Pump, Cooling Fan, and Headlight Schematics
1995-98 Stop Lamp and Turn Lamp Schematics
1991-98 Marker Light Schematics
1991-98 Back-up Light and Daytime Running Light Schematics
I hope help you with this. Good luck.
Sep 14, 2009 | 1997 Saturn SL
My 1997 saturn sl is leaking coolant. Where is
th pump is right under the ac pump take the passenger tire off and plastic cover and it is the bottom pulley on right
Jun 27, 2009 | 1997 Saturn SL
Locating the erg valve
It is located above the engine, right behind the air intake mainfold. Check beside the air Hose that goes to the engine, there you will find the valve held by two bolts. It looks like a round metallic object connected to several wires.
Jun 02, 2009 | 1997 Saturn SL
Pullys
Power steering on my 2000.
Engine is skipping when accelerating
to check the plug wires start car and mist the wires with a spray bottle of water if wires are bad you will see them arcing works best in dimmly lit area if they arc replace plugs and wires
May 29, 2009 | 1997 Saturn SL
Vehicle Parts & Accessories Logo
57 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
