Question about Minka Aire Ceiling Fan
Receiver in the fan
How do I "fix" the receiver in the fan? the remote's batteries are new and the coding hasn't changed but it is not working anymore
Just installed NEW Harbor Breeze Merrimack #40094 ceiling fan; it is remote only. Remote will not work from start, def pwr to fan and remote lights up;however, no lights or fan movement. Help anyone?
one thing to look at, the remote is fixed with different frequencies, take the back off maybe under the battery and change the little switch there it will beep when the remote is hooked up, battery on remote backwards or bad, did you get the power in the fan the right direction, Matt, when you tuen power off to the fan it will also beep, fimd the breaker,
Jun 26, 2015 | Dryers
Hunter douglas fan
Try changing the frequencies in the receiver & transmitter. If that doesn't work, you probably need a new receiver.
Oct 01, 2013 | Dryers
Remote doesnt work anymore
Fan remote stopped working. New battery installed.
Apr 14, 2013 | Lakewood HV 18-c Floor / Box Fan
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Fan cannot be controlled by remote. was working, now is not. new batteries. remote works on another fan of same type. changed DIP code twice. checked power source at ceiling. I give up! any ideas
Check the little window that receives the remote control information on the fan - it might be block from receiving the signal. Check the wiring from it as well on the inside of the fan.
Oct 29, 2010 | Hampton Bay 52 In. White Redington...
My ceiling fan/light can be controlled only by the remote control. our remote is not responding with the fan anymore. it has new batteries and has power, it's just not corresponding with the light/fan. it...
Turn the power off to the fan / light by flipping the breaker or pulling the fuse and keep off for 10 seconds then turn back on, it should reset the contol receiver in the fan.
Oct 27, 2009 | Hampton Bay 24002 Ceiling Fan
Need manual to program remote to a different frequency
Each fan with have a receiver unit mounted in the housing, usually above the fan up against the ceiling. Each receiver unit will have 4 "dip pins" which allow the code to the remote to be set. In order for two fans originally installed with the same code to be run separately, one fan will have to be taken down, and the code changed on the receiver unit. Then you will have to purchase a new remote and set the same code on its dip pins (usually under the battery.) It's easiest to buy a replacement remote WITH a receiver AND a transmitter in it. You can either wire in the new receiver (setting the code differently than the existing one on BOTH the receiver AND the transmitter) OR just put the receiver aside and program the new code that you've set in the old one into the transmitter.
Apr 25, 2009 | Universal Remote Control Hampton Bay...
Minka Aire Ceiling Fan Logo
51 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
