Question about Acer (ACERMOTHERBOARD)
System will not boot up. The bios does not even come up. Help.
  • dlfnvkb Jun 02, 2010
    Thank you for the info. It turned out to be the memory. Thanks again.
  • Acer Master
  • 4,924 Answers
In this case am I to under stand that eve if it has power it kinda boots in a loop or not at all..
1st ..If it seam to boot in a 3 or 4 sec loop ..it is a ram memory issue ..and you have to see if it has 2 units take on out and try again than change them between themselves to see if one is gone ..if it is just one ..remove it and put it back to see if it goes or not ..than if nothing changes open it and remove the bios battery to default it and make it see the hardware again from scratch ..and only after that consider to get another Ram memory ..and not before you try in in another laptop or get some ram to try and see if you change it works ..
If it just have power ..but it seams that after a few seconds shuts down and stops..than it may be a bios setting made wrong and the cpu maximum temperature is set too low ....and it gets to it sooner than the computer starts ..removing the battery should fix that too ..
If it has power but it is not booting at all..when you press the button ..than it sounds like a fried CPU unit ....and again just in case remove bios battery to see if it makes a difference (this action always put it on the factory defaults and if it is a case of sudden power lost and now its not recognizing the hardware ..this its making it see again all that have inside) ..
there can not be anything else but these 2 ..cause all the other hardware will cause not to boot in windows but let it show the devices and boot to bios..
Posted on Jun 02, 2010
Changed boot type from legacy to UEFI. Nowi cant even access bios and machine stops at acer screen. really need to enter back in bios and change back the boot type to legacy bios. Please need ur help
Changing the boot type will have no effect on whether or not you can still enter the bios.
The easiest way I find is to remove the hdd and RAM. Start up the laptop and it will do odd things. Power it off, replace the RAM with no hdd and go to the bios settings. Once there, reinstall the hdd and go to bios settings, reset back to legacy. Some systems will not support UEFI but if they do, a hdd without a system on a separate partition, will no longer work.
Dec 22, 2016 | Acer Computers & Internet
How to set dell 530 to boot from usb
During start up of your system constantly hit either F2 or F12 to enter Bios.
Once in Bios you can configure your boot settings to boot from Your USB device. Bios is pretty self explanatory even for those of us not to familiar with it myself even. Unfortunately mouse is not usanle in Bios. I've had to go to Bios many times on older systems just to boot from cd/dvd Also to correct problems others have made in the boot settings.
Anyway In Bios there is a little summary of each changeable feature within it. Once you make your selection(s) make sure to save changes so you do not have to keep resetting them to your own personal preference. You should be asked upon exiting if you want to save. Your machine should automatically restart and ask you to press any key to but from your device. If you do not hit any key your machine will but normally from harddrive and you will have to restart the system and wait for it to ask again.
Apr 19, 2014 | Dell Inspiron 530 Desktop Computer
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
Bios battery voltage is 2.4 volts, too low?
Hi there
It is a BIOS issue; try reflashing your BIOS since you dont have even a beep there is no any check on the system, even with a bad cpu, video or memory cards you should get a beep, so, reflash
Aug 26, 2012 | Computers & Internet
Hi, I have downloaded from DELL website the Dell Dimension 5150 BIOS to upgrade the BIOS. I followed all the steps successfully and restarted the system but it just showed incompatible BIOS on start-up....
first to get a properly bios you need to get the whole description and download it to an floppy disk if it does if not try to boot from a cd...theres a hirens boot cd tools to fix since you already flashed wrong i assume you have some experience use the key tag of yor dell to get properly drivers...
May 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I purchased on old acer aspire. it had a windows 98 upgrade. There were windows 95 and windows 98 files and 98se files, but half the programs were missing or the uninstall file was gone or corrupt. I did a...
You probably need to tell the BIOS to boot from the CD.
I'm not certain about your model, but you can try pressing delete button as it's doing initial start up, to enter bios. It may even display on screen what to press for bios. Then look for boot sequence options, and have the cd be the the first boot device.
If this works, you may see a message saying "press any button to boot from cd" if you don't do this , it will still fail to boot on cd.
If it works out for you, you should change this option back after completeing the install.
Mar 12, 2011 | Computers & Internet
My pc does not even display the bios setting .what should i do ? please help
when your computer boots up Does it say hit DEL for setup??? thats how you get to Bios( Basic Information Operating System) not windows . Windows is an operational syatem that runs the computer. Bios=settting for computer like where to install hardware,what handlers to assign to handle functions of the motherboard. Techs use Bios ,before setting up windows . Dont mess with Bios unless your a tech.
Jul 09, 2009 | Computers & Internet
Dont have post messages at boot not even bios version
sir u can go to the bios by tapping the f2 key while turning the system on immediately....
in the bios page the bios version id written.
also if the system is not booting up try disconnecting each and every device that is connected with the computer except for the mouse,monitor and keyboard.
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
System restore disk for HP compaq Presario 1700 help
hi, you may need to set your laptop to boot from the cd/dvd. you will need to enter the bios and check the boot priority. power the laptop as soon as you power on press either F2 or F10 to enter the bios (you have to be pretty quick with the F2 button). once in the bios look for the heading BOOT or BOOT PRIORITY F5 or F6 willchange the boot order.
hope this helps
Feb 22, 2009 | HP Compaq Presario 1700T Notebook
Computers & Internet Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
