Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Not cooling on control panel it says er 1f this has been going on for about a month it would flash on then go back normal now it stays on nothing is cool im afraid the freezer will thaw next
  • casey101101 Jun 03, 2010
    control panel er1f wont make ice refrige wont cool
    Brigadier General:
  • 3,513 Answers
ER IF means the icemaker fan is malfunctioning. Common cause is ice buildup in the fan shroud. LG has recently upgraded that shroud to drain off moisture that collects in there. The icemaker fan, when looking in the freezer, is the one on the left.
Very common for the icemaker itself to fail during the first year, have replaced many. They have since changed the design of it and it seems to have solved the problem.
There appears to be a problem with water splashing into the internal parts of the icemaker mechanism. The water then freezes up the works. You can try to make the unit go into harvest mode by pressing on the button on the icemaker (inside the door) for about 30 seconds -this will cause the unit heater to heat the tray slightly and the ejection arm will rotate and remove the ice.
Le us know if you want somethin more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jun 03, 2010
    President:
  • 1,561 Answers
Inspect the gasket for dirt or debris that could prevent it from sealing. If you find any, remove the large debris, then wash the gasket, using a scrub brush and warm, soapy water.
Check the gasket for cracks or tears that can let cold air escape. If you find any, replace the gasket. If the gasket appears to be solid, go on to step 3.
Check the seal: Open the door, insert a dollar bill partway and shut the door on the bill. Try to pull out the bill. You should feel some resistance. Repeat the test at several points around each door. If the bill slips out easily, replace the gasket.
If there is any circuit breaker, reset it.
Check for thermostat problems. It could be off or won't cool properly (too warm,). If it can't be fixed with a simple adjustment, call a professional.
Check for coil problems. The compressor can overheat due to dust buildup on condenser coils. If so, vacuum the coils.
The above are the likely problem and the solution.
Take care.
Posted on Jun 02, 2010
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
Jun 29, 2017 | Refrigerators
What is 1F code on kenmore elite refrigerator
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct.
Apr 17, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Front panal displays code 1F, and pads don't function
You are probably seeing the Er IF error code that indicates a problem with the ice compartment fan.
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct. If you are advanced in technical skills, you may be able to correct this problem yourself. It will require the removal of the inside back panel of the freezer compartment. This is not an easy task. I recommend that you review the procedure for this task that is shown in the image below. Make sure that you are able to safely perform the tasks described before proceeding with this repair. Unplug the refrigerator to disconnect electrical power before accessing internal components. Once you access the ice fan, you may find excessive frost in this area and on the evaporator that could be causing your cooling problem and fan problem. If you defrost this area, you may find that you do not need to replace parts. If you find no excessive frost or the Er IF error code resumes after removing any frost then you will likely need to replace the ice fan. You can order this part here.
Click here for the image.
Nov 21, 2012 | Kenmore Refrigerators
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The code er-1f displays on my control panel
the codes are listed back of your ref.and what they mean
Feb 08, 2010 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
73 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
