Question about Amana ABB222ZDE Bottom Freezer Refrigerator
Freezer not staying real cold--seems to be running all the time-what's going on? Coils are clean.
  • Amana Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer not staying real cold--seems to be running - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
Freezer is at 20F
The louvre that let's the air into the freezer is probably closed nearly ll the way shut, thus not allowing the cold air in. The same compressor runs the frig and freezer. Find where the air is coming in and there is where you should find your problem.
Feb 03, 2013 | Amana Refrigerators
New Refrigerator Past Warantee Not staying cold
It sounds like your condenser coils need to be swapped.
Replacement parts are available from the manufacturer and aftermarket suppliers. More conveniently, you may be able to find replacement parts through the retailer that sold you the refrigerator or at an appliance parts store.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Refrigerators
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
Jun 03, 2012 | Hotpoint Refrigerators
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Refrigerator cooling but not real cold, freezer freezes ice but
***UNPLUG THE UNIT***
Take the cover off the back where the tubes go from the compressor into the freezer. If you can see into the freezer AT ALL, you have a mouse issue. Plug this hole with expanding foam. If you're getting room air into the freezer and your door seals aren't coming apart, it's usually from the rear. Make sure to melt all ice that formed in the bottom of the freezer before you plug it back in.
Jun 29, 2009 | Jason Natural Cosmetics Jason Forma...
Neither the freezer nor the refrigerator is cooling properly
Check the evaporator coils on the back to see if they are warm. The cooling coils are supposed to be real cold. Sounds to me like you are low on refrigerant, and have a very small leak somewhere. I can't fix that from here, but service tech can find leaks, and recharge, but find cost first as you might just want to buy a new one as the other one is 10 yrs old. Hope this helps you, Rick
Apr 26, 2009 | Refrigerators
Amana ABB222ZDE Bottom Freezer Refrigerator Logo
48 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
