Question about Schwinn Windwood 26 Women s Cruiser Bicycle
Chain slipping after changing tire
Chain slipping in third gear after changing tire. how do we fix it?
  • 66 Answers
You may have knocked the gear derailleur when fixing and re-fitting the rear wheel. This can knock the derailleur out of whack slightly and will need proper adjusting by your local bike shop.
Posted on Jun 08, 2010
Why does used replacement A/T start in third gear?
code p 1753 refers to AT-lock up clutch not engaging/disengaging===causes --wiring--lock up control solenoid A---TCM ( transmission control module
I would start at the wiring harness and connections to ensure that all the pins are clean and straight
then I would get a known good TCM and change it out to see if the fix was effective
because you can get gears, I would at this stage disregard the clutch lock up control solenoid (torque converter clutch solenoid)
maybe for an exacting diagnosis of the problem, a discussion and inspection by an accredited auto transmission specialist shop the deals with your make of vehicle would save money in the long run
Apr 02, 2016 | 2001 Acura CL 3.2 Type S
Bujaj Pulsar 150 chain set problem
Hi, Yes, If it is worn out. do so. Chain and gears do wear in time and will slip or skip over. So both gears and chain will have to be replaced with new...
Jan 14, 2014 | 2007 Bajaj Pulsar 150
Sounds like my chain has gone but how long can this last is it very dangerous can the chain come off at all? the teeth on the sprockets are still very good and sharp but does sound like its slipping s
You need a new chain, a worn chain will not match up properly with a new gear/cog. You can do this yourself, the chain should have a link that will come apart.
Nov 19, 2013 | Suzuki RF 600 R Motorcycles
Third gear slips makes rattling sound like chain slipping ova cog
3rd gear is wasted. your going to need to have the trans repaired.
Apr 03, 2012 | 2005 Buell Firebolt XB12R
On mountain bike the chain or peddles seem to slip or click goning up a hill. Is it the chain slipping or worn gear?
It sounds like your chain is loose. Flip the bike over and loosen up the nuts on the back tire and tighten the nuts as you are pulling the rim back making the chain as tight as you can. You might need someone to help you pull as you tighten the nuts.
Aug 26, 2011 | Cycling
Stairmaster freeclimber 4400pt how to fix slipping chain. When using the machine the chain slips intermittently on both sides. Problem was infrequent in the beginning but getting worse all the time with...
This could be the hub assembly slipping I would replace this assembly and the pedal chains call National Gym Supply @ 800-496-7278 and get pricing for the hub assembly and step chain ( L & R )
May 25, 2010 | Stairmaster Exercise & Fitness
Internal gear slipping ,seems like rart of gear
you may be able to fix your problem by tightening up the chain a bit more. other wise, you may have to have that gear replaced because as you indicate it may have had it's teeth worn down. i would begin by tightening the chain.
Aug 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain slips on up hill grade only and I've pulled the rear tire back to tighten the chain as much as possible.
You may want to take your bike down to a local shop and have them put a chain guage on the chain to see if the chain is stretched... This should be a free service...
If the chain is stretched, it will tend to want to jump when under pressure... if this is the case, the chain should be replaced before further damage to the gears occurs...
May 27, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Transmission slips in and out of third gear
sounds like you need to have the fluid changed and a new filter put in.. good-luck ray
Jan 02, 2009 | 1996 Lincoln Town Car
Transmission problem
I will be trading in car or fix by dealer . NICO club more helpfull thanks anyway.
Sep 12, 2008 | 2004 Nissan Sentra
Schwinn Windwood 26 Women s Cruiser Bicycle Logo
244 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
