Question about Homelite Mighty Lite Lawn Trimmer
Weed eater will not idle - Homelite Mighty Lite Lawn Trimmer
My unit does the same thing and my only suggestion is to throw the piece of **** in the trash and buy a battery powered unit. Otherwise you will pull all your hair out and your neighbors will call the mental institution on you for your erratic and dangerous behavior
Posted on Jun 03, 2010
My murray m2510 gas weed eater runs at idle but when i go past fast idle it wants to die. i put a new spark plug in it, it didn't change. what could be the problem? it started doing it last fall.
Sounds like fuel problem. You may want to check the vent on the fuel tank. It can get clogged and won't provide enough fuel to run at higher rpms. I'm not familiar with that engine, but its a problem I've had in the past with weed eaters and chainsaws.
Apr 07, 2016 | Fast Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
2009 31cc toro weed eater wont stay running. will fire and run at idle but wont stay running in 1,2,3 settings
get a can of starter fluid and a helper. Start the weed eater and then squirt enough starter fluid into the air intake to keep it running while you move it through the settings. This will rid your tool of the crud that is causing your problem. Joe
May 07, 2010 | Garden
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a slight missfire when at idle
All harleys skip and vibrate like a weed-eater. After you ride one a while, your hands and other parts get numb just like operating a weed-eater. Real 21st. century bikes do not have chains or belts! I just took off the wheel weights off of my car so it will feel like a harley going down the highway. Check plug and wire for carbon tracking and replace both at the same time. Check for vacuum leaks.
May 03, 2009 | 2006 Harley Davidson FLHRI Road King
Homelite Mighty Lite Lawn Trimmer  Logo
181 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
