Question about Standard Registar SD650 Color Copier
I have a sharp am90 copier. My copies come out with a black streak on one edge of the paper. I also noticed that the drum has a thin black powder line on it. When I wipe it off it appears again as soon as I make another copy. Does my copier need to be cleaned or do I need to replace the drum. My toner is not empty.
  • pritchardsba Jun 02, 2010
    I wiped the drum clean but still the black streak appears. What other part do I clean?
    President:
  • 4,070 Answers
Hi! The drum will need replacement for it produces black powder that results to poor printing. Once the drum is replaced you'll be good. Hope this helps and have a good one!
Posted on Jun 02, 2010
  • 4,924 Answers
First this is a issue of cleaning the developer cause it has something caught on it ..and due to the static electricity accumulated its attracts the stray toner in that point ..and the fact that the drum even cleaned it is getting dirty in the same spot proves it ..So ..open it up ,,,and clean all the parts drum developer and rollers..and only after that if it still comes back to the same problem ., you will have to consider other issues..like the waste tank full ...or a defective cartridge that disposes the ink in a faulty way ...Usually it is just a matter of cleaning and resetting ..
  • Catalin Turcu
    Catalin Turcu Jun 02, 2010
    developer and rollers..and all tha came in contact with the drum and may cause it to get dirty ..
How do i remove a white streak that runs down the
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
May 04, 2010 | OKI C5200n Laser Printer
Tip
Why i get black streaks on paper in laser printer prints?
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks .
on Mar 18, 2010 | Office Equipment & Supplies
Streaking on left side of page
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | HP LaserJet 1200 Printer
Black Streaks on copy
This means that teflon is wearing off of the Fuser Roller. It collects toner and then tracks it back on everu copy. It needs to be changed out by a trained tech.
The other thing that can cause this is a bad drum. Both about $200 I believe.
Cheers
Dec 29, 2009 | Sharp Office Equipment & Supplies
HP 2840- vertical black streaks on paper edges when copying using black only- copies fine in color
The Drum unit is worn or defective. try another drum unit. this should take care of your problem.If it's new then get your money back and replace it.
Dec 10, 2009 | HP LaserJet 2840 Printer
My copier is a Sharp SF Model 2215. I replaced
It is the drum.
Reasonable cost? That's up to you.
Call a few service depots and ask. Then decide if you want to invest the cash.
Jul 14, 2009 | Sharp AR-M205 Copier
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
Jul 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Light and streaky copies, and a powder residue.
make sure that the machine is level first. then you will have to change both the drum unit and toner cart with new units not just change the drum in the drum unit.
Nov 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Standard Registar SD650 Color Copier Logo
Top Standard Registar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Standard Registar Office Equipment and Supply Expert? Answer questions, earn points and help others
