Question about Fuji FinePix F650 Digital Camera
WHEN I TURN MY CAMERA ON I GET A ZOOM ERROR, AND THE LENS WILL NOT MOVE AT ALL
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 04, 2010
cyrylthewolf
  • 143 Answers
SOURCE: Lens error
It definitely does sound like one of a few things:
  • The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes out.
  • The motor or servo that drives the transmission system is failing.
  • There is a physical deformity of the lens architecture itself that is preventing the lens from coming out.
Any of these symptoms is most likely going to be accompanied by a grinding sound. Especially if the gears are somehow stripped. The "puttering" sound be a description that would fit the sound a motor or servo makes when it's trying to cycle itself over but is failing. (Much like a car that is trying to start up, but just won't turn over?) That would definitely be an indication of a motor going bad in the camera.
Either way, this is something you're definitely going to have to refer to Canon's technical support on. If your camera is still under warranty, you're going to have to get them to replace it or at the very least SERVICE it.
I myself will ALWAYS insist on REPLACEMENT. One might argue that the terms of the limited warranty state that they reserve the right to either replace or service the device...
...but TRUE customer service tells a different story. I have NEVER had anything serviced. I have always had replacements. Either I've INSISTED on it or they've just been smart and not even made it an issue by making it their procedure. I get a brand spankin' new device and THEY get a happy customer.
Always keep in mind how much you spent on their product and ENGRAIN that into their heads.
Here's the deal...
If you ARE out of warranty, get around that by telling them that you DID buy it within the last 9 months and that you do NOT have proof of purcahse. If they insist on asking for it, then humor them and "try" to look for it and once again inform them that you do NOT have it.
They can't really dispute the warranty at that point if they can't prove that you DIDN'T buy it within the last 9 months.
I hate to work the system like that... But I paid $400 for mine. I'll be damned if I'm going to be out the money for it! Am I right?
Anyway... That is the best advice I can give you, unfortunately.
Call them as soon as you can! Get it replaced!
If you think that you can keep yourself together and composed well enough to play the system... Contact Canon's tech support and see what you can accomplish.
Remember... It's not as if you're going to get in any trouble. The worst they can do is refuse you. You have NOTHING to lose but the money you spent on the camera!
Here is their support info.
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Good luck with this. Let us know what comes of it. :)
Cyryl
Posted on Nov 17, 2007
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Posted on Feb 19, 2008
emissionwiz
  • 77169 Answers
SOURCE: camera focus error
there is a small logic circuit that controls the motor that retracts the lens and a sensor that tells it the lens is retracted, it is a lens position sensor, one of these two components is most likely defective, the thing is there are no consumer service info provided by panasonic, they will not sell you parts either, the camera is a mystery to take apart and repair without the tech manual which u can't get, so u see the delima here, u must either have this camera fixed by a panasonic repair station or see if it qualifies for a upgrade exchange program for a newer model.
Posted on Aug 07, 2009
  • 11967 Answers
SOURCE: Zoom error on screen and shuts off
Posted on Mar 25, 2010
lock123
  • 6831 Answers
SOURCE: fuji film finepix f20 zoom error. it's stuck and won't move
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Lens error 122,1,0,0
Most likely, the lens movement gears are misaligned. There's also a good chance you misaligned the lens elements by knocking the lens sideways. It is not going to work, since it cannot move the lens to focus or zoom now. Your choices are to repair or replace the camera.
Oct 15, 2009 | Kodak Easyshare M753 Digital Camera
When I turn on the camera I get an error message "lens error - restart camera" Have not seen this before
the chip set in your camera is damaged.you want to go to a near by servicing center to repair it.
Aug 27, 2009 | Cameras
Zoom Error?
Dirt in the focus motor drive gears right behind the lens at the front.
It's a **** design (my opinion). The lens at the front moves in and out depending on your zoom level. It can come right out of the lens barrell at the front. So, if it can come out, dirt can get in. and it's a pig to clean out and reset. Bin it or sell for parts.
Jan 25, 2009 | Fuji FinePix A500 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Zoom won't go in or out canon power shot sd870
zoom will not work in movei mode.
operate zoom before shooting in movei mode.
Apr 09, 2008 | Cameras
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
E 18 Message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
Fuji FinePix F650 Digital Camera Logo
345 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
