Question about Kenmore Elite 45986 Front Load Washer
Code f02 the washer machine stop working and the water flooded.
    President:
  • Kenmore Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is, in short: FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl. rate me nice for the free help!
Posted on Jun 03, 2010
Testimonial: "Thank you fix68 i cleaned the drain filter and now it works great!"
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 shows on my washer...what does this mean
The F02 Code usually means the washer machine can't drain the water. Usually caused by a failure of the drain pump or a clog in the drain hose.
Dec 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool washer GHW9100LW F02 code - -what does that mean?
F02 – indicates a Long Drain error (Drain Exceeds 8 Minutes) - Select 'cancel' twice to clear error code.
Note: You may see a "SUD" error code appear first during this failure.
This should change to the F02 error code after a few minutes.
1. Switch off the machine, unplug the machine from the mains power and turn off the water supply to the machine.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 28, 2009 | Whirlpool Washing Machines
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE4 washer won't drain. gets code f02
take bottom panel off ,,it has a screw out filter,,this filter fits directly in your pump..its clogged,,your pump is the fist part you see when you open bottom panel
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
175 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
