Question about Janome Memory Craft 4000 Sewing Machine
What is the purpose and use for feed balancing dial?
    New Friend:
  • 184 Answers
The feed balancing dial is for adjusting some decorative stitches that do not form correctly because of the type fabric being used, for instance, the stitch seems too close together to form the design. You would turn the balance towards the plus side. It will also affect the buttonhole sides, if one side seems different in stitch density than the other then you would adjust the balance.
Posted on Jun 03, 2010
Testimonial: "just couldn"t find an explanation ...so asked the expert..and thank you ..wrote it in my booklet..."
Does this model have a feed dog that can be lowered for free motion quilting?
    A set of feed dogs typically resembles two or three short, thin metal bars, crosscut with diagonal teeth, which move back and forth in slots in a sewing machine's needle plate. Their purpose is to pull ("feed") the fabric through themachine, in discrete steps, in-between stitches.
    Feed dogs - Wikipedia, the free encyclopedia
    https://en.wikipedia.org/wiki/Feed_dogs Wikipedia
Oct 25, 2015 | Sewing Machines
How do I stretch sew on this machine the stitch is either too tight or looping and what do I put the feed balance dial on + or - to sew this stretchy fabric
IF YOU HAVE A ZIG ZAG STITCH, SET THIS ON A LONG NARROW LENGTH AND USE THIS FOR STRETCHY FABRICS. ALSO USE A NEEDLE FOR STRETCH FABRICS OR A BALL POINT NEEDLE, IF YOU HAVE ONE, AS THIS IS BEST.
May 06, 2015 | Sewing Machines
Feed dogs are not feeding
Either they are clogged with lint, or if you remove the base and find shredded gears (esp Singer)....not good
Nov 10, 2011 | Sewing Machines
There is a knob on the left side of machine, I don't know what it does or used for. The manual didn't make it to me with the machine. I figured out the threading, but the tension is too tight. I would...
The knob on the left is the Pressure Foot pressure dial. Here is what the manual says about it: " This dial regulates how hard the presser foot is pushing down on the fabric. To little pressure may cause poor feeding of the fabric, skipped stitches, or difficulty in guiding the fabric as you sew. Too much pressure may result in one layer feeding ahead of another or feed teeth or presser foot marks on the fabric. For most fabrics set the dial at 2. For thicker fabric increase the dial to 3 and for thin fabric decrease to 1." The red dial on top, the far left one, is the tension dial. Just have to play around with that til you get it like you want. Hope this helps!
Jan 12, 2011 | White Sewing 2037 Mechanical Sewing...
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
As I'm sewing with my Bernetta 730 dog feed
The feed unti dialed inside is seized , you can try removing the freearm plate and adding oil then manual turn the dial back and forth unit the feed dog drop. this will correct the problem for another 30 years
Apr 19, 2010 | Bernina Sewing Machines
The feed dog is not grabbing the material or the presser foot pressure doesn't seem to be working. I have a Viking 6000 SL sewing machine, Model 6460.
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Oct 23, 2009 | Husqvarna Viking 1
Elna 2002 -
The question was regarding the Elna 2002 not 2007 and it wasn't a problem. I just do not understand how the pattern selection works. Thank you.
Dec 04, 2008 | Elna 2007 Mechanical Sewing Machine
Kenmore sewing machine 19233
The 19233 hasn't got a presser foot regulator on it. Not all sewing machines do, especially the newer ones, although there is a Kenmore that is more expensive that does. I haven't needed it al all anyway, and am not used to it on any other machine. I used to have this on my Pfaff, but never used it.
Jun 05, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
474 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
