Question about Cell Phones
How to remove the error or format the SD card of my blackberry cellphones?
  • 5,081 Answers
  1. Open a web browser, and navigate to the URL for the SD card formatting application..
  2. Click the "I Accept" button to accept the terms, and continue the installation.
  3. Save the installation file named sdfv2000.exe (or similar) to the hard drive.
  4. Right-click on the Windows "Start" button, and select "Explore" to open Windows Explorer. Navigate to the saved installation file.
  5. Double-click the installation file to install the software.
  6. Click "Yes" to accept the second terms of use statement for the package.
  7. Confirm or change the location for the program installation, and click the "Next" button to continue. A progress icon will monitor the installation process.
  8. Click "Finish" when the progress bar has reached 100 percent. A text file containing instructions and credits for the formatting software will automatically open in Notepad.
Posted on Jun 03, 2010
My device is not a cellphone. Its an android but i followed some of your directions.
unmounting allows for safe removal of the sd card from device,meaning when you unmount the device doesn't read the sd card anymore until you remove it and insert again...erase basically formats the sd card
Nov 26, 2015 | Android Cell Phones
SD error SD card loading
Try inserting it to another device. If the phone can read the SD card, then there's no problem with SD card. There may be a problem with the card reader on the Samsung phone. You may also try to restart the samsung phone. Also, you can try to format the SD card on another cellphone (go to the memory card > option/menu > format or repair) or on a computer that has memory card reader.
Mar 08, 2011 | Samsung Cell Phones
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
How to remove write protected memory card
Dear the card adaptor which you are using on the side of adaptor there is a side lock please check it may be it is lock that's why u r not able to transfer data.
May 20, 2009 | Motorola Mobility L6 Cellular Phone
My computer will not format my memory card for my blackberry
Put SD card into adapter format on PC Fat32,
put in blackberry should work fine.
Apr 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cant format sd card
Your sd card may have too much memory or it may be an hd
Mar 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Nokia 6600 chellphone
try to remove your sd card and open it in a pc using a card reader... there you can copy the files and transfer it to other disk... maybe its almost full.. make a copy of everything and format your sd card. this will give you more space. 6600 slows down if the memory card is loaded try to remove other files especially large files. a full sd card slows down the cp's performance...
Aug 26, 2008 | Nokia 6600
Medoa card
1. Press Blackberry Button
2. Go into Options
3. Go into Advanced options
4. Select Media Card
5. Press Blackberry Button
6. Select Format Card
If this does not work, get hold of a MicroSD to USB convertor put into PC and format that way.
Useful program:
Please go to the site below:
http://www.sdcard.org/about/downloads/
SD Formatter Ver2.0[2.0.0.3] exe file (1.315Mb)
Install the program in your computer, then insert the card into the card reader (if you do not have reader, you can try to connect your device to the computer with USB cable) and then run it:
a. Check the drive letter and also the size and make sure it is the correct card.
b. Click Option:
Format Type: Full Erase ON
Format Size Adjustment: ON
c. Click OK, then click Format. Wait until it finish.
d. You will be prompted to remove the card after it finish.
Hope this helps
Gadget
Aug 25, 2008 | RIM BlackBerry Pearl Smartphone
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
