Question about Ovens
Its work for 2 min and turns off and cool down and turns back on and work for another 2 min
    President:
  • 1,561 Answers
Make sure oven is plugged in properly.
Check that door closes completely and its latch is aligned.
Check that interlock switch in door works properly.
Check the power cord to make sure it is firmly plugged into the outlet, if the microwave is not working. If this is acceptable, check to make sure the door closes correctly. There should be a click and the door should not reopen without pushing a button or exerting at least a little energy to pull it from the latch.
Check the oven settings. Make sure the settings are set to 100 percent and the food should begin to cook properly.
Most importantly, check the control panel because it is possible that there is bridge on the control panel that is why it restart itself every 2 minutes.
Take care.
Posted on Jun 02, 2010
I cannot open oven door after cleaning cycle has been done for 2 hours
Unplug the oven for a few min's and see what happens.
Aug 28, 2017 | Ovens
My oven turns itself off when on fan forced when I put temperature to 225 why I am left with stuff in oven no fan it comes back on after round 10 mins
Pls be more specific with make and model to get a better answer. But it sounds like it can be a problem with your safety thermostat that is set lower then 225 and that couse the oven to switch off and when it cools down to the temperature that the safty stat is set on the oven will reset and start working agian
Jun 29, 2015 | Ovens
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
I have a ken more elite double oven. I set it for 425 for 30 min and was to turn it back. I am cooking a chicken. I didn't have my glasses on and accidentally turned the flex and clean on. Now
sure you'll be able to open it but your chicken will be burnt to a crisp. actually, it may not if you just hit cancel right away after starting the self clean feature.
Nov 14, 2012 | Ovens
My AEG B3191-4 oven works for about 30 mins, then seems to cut out... it won't work at all until it has cooled down, and then the cycle starts again... can you tell me which part is likely to need...
Your cooling fan may not be working. either the fan is faulty or its controling device is not switching it on it also allows the fan to run on after the oven has been turned off. its located in the wiring loom behind the switches. part 899661926761-1 costs £26
Jun 08, 2010 | AEG B3101-4 Electric Single Oven
I turned on the self cleaning process let it clean and cool down Tried to bake next day msg states to unlock door even when the door is open can't use oven help I have tried several times to lock and...
since i dont know your model try this
unplug the range for 30 mins
let the memory clear
and then plug it back in
this works for several differant manufacturers
Oct 13, 2009 | Ovens
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
Stove 720g Grill
HI YOU MIGHT HAVE A SAFETY THERMOSTAT THAT COULD BE FAULTY.BEST YOU HAVE A TECH TO HAVE A LOOK AND REPAIR.
GOOD LUCK.PLEASE RATE THE SERVICE.
MOHAMED
Sep 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Oct 23, 2007 | Electrolux ICON 30 in. Double Wall Oven
Ovens Logo
54 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
