Question about Gateway MT6840 Notebook
My gateway mt6840 does not read my new battery
My gateway mt6840 does not charge my new battery
  • 95 Answers
Have you tested your power supply to confirm it's sending out the right amount of current.A simple ac tester is all you need.On the back of your power brick it will tell you your in-put and out-put voltage requirements.If your ac adapter tests good your new battery is probally the problem.
Posted on Jun 03, 2010
2 Suggested Answers
  • 615 Answers
SOURCE: Gateway mt6840 new battery will not charge.
check the connection between the battery and the unit and clean them good try to use elctronic cleaner
Posted on Sep 08, 2009
Gateway MT6840 won't power up
before checking ur mother board check for ur operating system.
Mar 08, 2012 | Gateway MT6840 Notebook
Hi I have a Gateway MT6840 laptop. The problem I'm having is it won't run or charge a good battery. I have borrowed a friends Gateway MT6840 laptop to test it and my battery charges and works great in his...
Are you sure that the charger is working?
If not it could be the battery slot. There is nothing you can do on your own except swap batteries ant try.
Mar 03, 2011 | Gateway MT6840 Notebook
What model DVD/CDRW drive do I need for my Gateway MT6840 laptop?
Gateway Part Number: 2527904R
GATEWAY MT6840 8X SUPERMULTI DVD DRIVE> try this one.
Mar 29, 2010 | Gateway MT6840 Notebook
I have a gateway MT6840. I am having charging problems.
This problem requires the dismantelling of the system and the socket either being resoldered to the motherboard or replaced if it is damaged. if you cannot or are not comfortable with doing this yourself, you will need to get a tech shop to do this for you.
Feb 12, 2010 | Gateway MT6840 Notebook
Gateway mt6841 won't turn on or won't take a charge, no lights when ac adapter is plugged in
Hello
Thank you for using FixYa for your problem
Always check the charger unit is acturally giving out the power, then it maybe the DC Jack in the laptop (where it plugs in) Is this loose
It should be taken to an authorized repair centre for a repair estimate.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Gateway MT6840 Notebook
Gateway mt6840 new battery will not charge. New charger too. Bad charging port? Bad charger board?
Sep 08, 2009 | Gateway MT6840 Notebook
How to remove the case on gateway mt6840
Have you taken a laptop apart before?Easy to break something but you can do it.go to gateway.com/support and you can dowLoad the instructions. this should solve the problem.RICHARDM69
Jun 05, 2009 | Gateway MT6840 Notebook
Cant get it to turn on or charge
Flashing red light 3 times and won't boot. I recently recalibrated the battery and again the 3 flashing red lights. Seem to be draining the battery fast. It's also a new battery...which work for about 2 weeks before the 3 flashing red lights first started. Now 2 batteries later. It won't boot.
Apr 26, 2009 | Gateway MT6840 Notebook
Gateway solo mt6840 power input is not working
I had the same exact problem, the computer techs I talked to all said it was either the DC Jack or the Motherboard. They will need to open your computer to check this out and they usually charge to do this. I had the DC Jack replaced and still had the same problem so their next suggestion was to get a new Motherboard which can set you back quite a bit. Try to find a Computer repair shop who will give you an estimate at a minimum to no charge, also ask if they are able to fix the Motherboard without totally replacing it if this is the problem. This will most likely be at half the cost of a new Motherboard. My computer was fixed for a total of $220, that was $150 for a Motherboard repair and about $50 for the DC Jack repair. The only drawback was the company ended up damaging the body of my computer and won't own up to it. Whatever you do, don't send it to Pell Technology and get it done in the near vicinity. Also take pictures of your computer before you leave it with any computer repair shop.
Apr 09, 2009 | Gateway MT6840 Notebook
Gateway MT6840 Notebook Logo
205 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
