Question about Altec Lansing VS3251 Speaker
5.1 SPEAKER SETTINGS CHANGE AT EVERY RESTART
I have properly connected the speaker wires to main
unit , in correct polarity. I started plugging cables by clicking on
blue,green,pink indicators on realtek on board sound card software. I am
able to set all speakers in correct manner and there is no such distortion
in sound as such.To update my details , i have two operation system on my
pc, i.e XP ULTIMATE, & VISTA on seperate drive partitions. I have reloaded
my audio drivers as well as have clean formatted my machine twice to
establish a fresh install. Even though ,after going through this turnmoil ,
my speaker settings change every time i restart my PC in any operating
system . I am using Intel G31 motherboard, 2.2 ghz processor,NVIDIA 8300
graphic card. Is there any correlation whether on board sound card drivers
are not compatible with this set of speakers or do they need a lates update
to match the speakers ???? God knows or You know ?? help! help! help
  • Anonymous Apr 27, 2008
    yeah i got 2 operating system too..xp and vista onb different partitions..before when i was still using xp only,my altec lansing speakers do good..i mean hav no problem with the surround but now i cant use it as 5.1..i mean only the front and the bass works in vista.however in xp the sound switches i mean the rear speakers sounds when its time for the front speakers..ive try reinstalling everything..thank's..
  • 58 Answers
Having multiple os's should not effect the settings it sounds like something directly related to the software you all are running for the surround. what is this sofware and is it updated, does it belong to the sound card or the speaker setup ?
Posted on May 11, 2008
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
Sep 11, 2016 | Panasonic Audio Players & Recorders
Tip
Using Proper Speaker Polarity
Sound system speakers have standard polarity which is indicated either with a "+" or a "-", or with Red and Black colors near the speaker terminals. This same polarity marking is also found on the sound system amplifier section. Most speaker cable has a polarity indication; either color coded, or a physical difference in the wires. Reversed polarity results an obvious decrease in bass, and a hollow sound in the mid range frequencies. If your speaker cable has no obvious polarity indication, you can check the polarity as follows; connect a 9V battery to each speaker cable for no more than about a second; long enough to see the woofer cone move. When the + battery terminal is connected to the + speaker lead, the woofer cone will move out. When you have this situation, label the positive speaker lead, either with tape, or by tying that wire in a simple knot. Make sure both cables are checked.
on Oct 06, 2010 | Audio Players & Recorders
How do I troubleshoot a "check speakers" warning when they are connected properly?
Sounds like your using the YPAO to check and setup your speakers but if the speaker in question is a bipole, dipole, oe omnipole those types of speakers will fool the YPAO and you might get a result that tells your the speaker polarity is wrong, so if you are 100% sure the wires are correct then just ignore that warning. I have Ominpole speakers myself and I always get an error telling me to switch the wires and change polarity but even if I do that I get the same error so I just have to make sure the wire are hooked up right and ignore that error
Aug 18, 2014 | Yamaha RX-V659 Receiver
My unit says over load shut off power and turns off 2nd set of speakers???
Here are some things toy can check and try.
Connection faults
Check the speaker cables for shorts or damage. Crossing speaker wires can destroy receivers.
Some units are sensitive to speaker polarity problems. Make sure both sets of speaker cables have the correct polarity.
Very thick, or otherwise incorrect speaker cables can also cause faults like this. Try thinner wire if you are using very thick wires.
You may have the wrong speakers. Check the resistance the unit expects (usually 4 or 8 ohms), and make sure it matches. Try different speakers.
Could be other speaker faults. Some active speakers can develop faults, or there may be an internal fault in the speakers. Try different speakers.
Thermal overload:
As a general rule, don't run the second set of speakers if you don't need them - usually runningthem will degrade audio quality, increase power consumption, and increase the liklihood of thermal overload.
Try listening on a lower volume, see if it still does it. I have a unit that behaves this way mostly in summer when it is warm. If it does not do it when the volume is low, that's an indicator it may be thermal overload.
Check clearances. Don't block vents or place the unit in an enclosed space. Check the manual for a guide.
Check for dust, you might need to open it, (This will void the warranty if any, and can be dangerous even if the power is disconnected). You may use an air blower (like in a can) to clear the dust - or carefully use a vacuum cleaner).
If you suspect thermal overload, try pointing a domestic fan at the unit and see if it still does it.
Internal fault
Sometimes faults in the unit can cause these sort of symptoms. I've seem problems with volume knobs, and other parts. You'll need a proper service agent to investigate if this is suspected.
May 13, 2014 | Teac AG-V8060 Receiver
There are 2 wires from crossover to Acoustic Research Phantom 8.3 Titanium Tweeters. One wire is Brown, other Green. Tweeters have one terminal marked with red paint. Some of my speakers have Brown wire...
Normally Speaker and Amp side will mark correctly the polarity. If wrongly connect phase may get wrong. If you understand or may know the different by hearing, if both tweeter phase is wrongly connect, what need to do is reverse the connection of one side the phase will change. you can try which give you the best listening feeling.
Feb 08, 2013 | Acoustic Research Phantom 8.3 Main /...
PROTECT AND PUSH POWER IN THE VISOR.NO SOUND,NO NOTHING WHAT CAN I DO?
This happens when the speaker wires are not connected properly. Remove all speaker wires from the back of the unit, and re - install them, in the correct order and with the correct polarity (white stripe on wire to red terminal, no stripe to black terminal)
Hope this helps.
Jan 24, 2011 | Sony DHC-MDX10 Shelf System
How do I hook up banana plugs to a infinity PC 350 speaker
The illustration in the manual I found at retrevo.com isn't detailed enough to show the axial connection option, which would normally accept a banana plug inserted straight in if the opening is conductive and about 4mm wide. I suspect it is as they mention a "variety of wire connectors".
Their only illustrated example show bares wire ends inserted into a small hole drilled through the termial post and the red or black plastic piece tightened down to secure it.
WIRING THE SYSTEM
IMPORTANT: Make sure all equipment is turned off before making any connections.
For speaker connections, use a minimum #16-gauge speaker wire with polarity coding.The side of the wire with a ridge or other coding is usually considered positive polarity (i.e., +).
NOTE: If desired, consult your local Infinity dealer about speaker wire and connection options.
The speakers have coded terminals that accept a variety of wire connectors. The most common connection is shown in Figure 5.
To ensure proper polarity, connect each + terminal on the back of the amplifier or receiver to the respective + (red) terminal on each speaker, as shown in Figure 6. Connect the – (black) terminals in a similar way.
See the owner’s guides that were included with your amplifier, receiver and television to confirm connection procedures.
IMPORTANT: Do not reverse polarities (i.e., + to – or – to +) when making connections. Doing so will cause poor imaging and diminished bass response.
Feb 20, 2010 | Infinity PC350 Center Speaker
Putting Speakers in Door Dont Know how to wire them correctly
Wiring speakers with reverse polarity doesnt have adverse effects. It cant give distorted sound. Seems like the wiring from the head unit to the speaker might be at fault. For testing purposes, connect the speaker directly to the head unit, bypassing, the car wiring. If the sound comes out alright, you have to replace the car wiring. If it is still distorted, speaker might be at fault. Try with a different speaker.
Oct 20, 2009 | Pioneer TS-G1642R Car Speaker
Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Jan 04, 2009 | Bose Acoustimass 16 Speaker
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Dec 12, 2008 | Bose Acoustimass 16 Speaker
Altec Lansing VS3251 Speaker Logo
421 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
