Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Drain tube apparently doesn't allow condesate in ref to drain out
It's a older 550 and the rear drain freezes in the ref and then eventually drips and leaks in the front of the ref door.
  • Sub-Zero Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerdrain tube apparently doesn't allow condesate in r - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 04, 2010
Why does water drip inside the ref toward tne rear of the ref? Happens once a day
That's the automatic defrost cycling. The water collects at the bottom and drains into a flat pan underneath for eventual evaporation.
Jul 19, 2014 | Hotpoint Refrigerators
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
Why is there no drain hole for condesation to drip out?
Some of the Friedrich units will drip out in the back of the unit. There may be just a small bend in the base of the unit allowing a certain amount of draining just behind the rear coil. Most units require some water to remain in the back of the unit to help cool the unit off. This is why tilting in the window is important. Be sure not to tilt it too much or too much water will drain, causing the unit to overheat. Be sure to tilt it enough to where the water can drain properly or the water may drain in the house, down the wall.
Jun 20, 2011 | Friedrich CP18F30 18000 BTU ThruWallWindow...
Water is freezing in the tube feeding into the ice maker. What could be the cause?
Generally the cause is a defective water valve that feeds the icemaker.
The water valve is allowing a small amount of water to leak past the seat. The water then slowly drips down the icemaker fill tube and freezes in the tube causing a blockage of ice to fill the diameter of the fill tube.
Replace the water valve.
Clean or replace the water supply valve that supplies the house water to the water valve on the ref.
This will ensure trouble free ice maker operation.
Jan 16, 2010 | Refrigerators
Water dripping out of a tube on the fire wall, passenger side
outside the car:
condesation drain from the A/C evaporator core. all perfectly normal.
inside the car:
Clogged condesation drain tube.
Aug 15, 2009 | 2000 Ford Windstar
WATER DRIPPING FROM TOP OF REFRIGS MAIN COMPARTMENT
The drain is clogged.
This water should be going down the drain to a pan under the ref.
The drain starts under the cooling coils in the freezer but can be clogged anywhere. Some models will have access in the main ref in the top - rear, a small cover can be removed. Some will have access on the back of the ref. you can see the drain tube and an elbow where it come out of the ref. remove the elbow and check for clogs.
Dec 11, 2008 | Whirlpool Refrigerators
Water keeps filling bottom of lower freezer in my refrigerator
sorry, about the timing, you have aclogged drain tube, your "self-defrosting" refrig isnt able to allow the derforst water to escape( tube if frozen) so it baks up into the frezzer area and eventually will drip into the frig. you will need to remove the back cover of freezer sect, and with a hair dryer remove all the ice from the drain trough area and clear the frozen drain tube area
Sep 23, 2008 | Refrigerators
Subzero 550 water drain in refrigerator section backs up
The problem is that the water freezes in the drain, either because the door is not sealing good, it's open too often or there is mold in the catching tray and tube. Best solution is to take a turkey baster (pump), disconnect the flexible tube from the tray, by pulling down, take a large cup with very hot water mixed with a spoon or 2 of Clorox, fill the baster with that mixture and pump it on the drain tube. You have to do it several times, water will come out, but do it until you hear a "woosh" sound and the water goes freely on the drain. Also spill some of that mixture in the tray so it kills the mold.
Apr 04, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Z 550 reidge internal leak
The tube behind the crisper drawers is not insulated well enough and will repeatedly freeze, leaving the water to drain on your floor. The solution is to thaw the tube and put a piece of copper the length of your tube, into the area below. The wire extending into the area below is just warm enough to keep the tube from freezing.
Aug 19, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
289 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
