Question about Watts Onan Portable Generator - 4000 , Model# 5500
I have an onan microquiet 4000 KY. It will not start, fault code on red light indicates (35) control card failure. I took it to local rv repair, and 150 dollars later they told me what I already knew. they said command board bad. 600 for new board. plus labor. I said bye. before I take it to authorized onan repair is their anything I can do myself? Can I replace board myself? I checked dc voltage at unit, I have 12.65 volts. Any advice would be great... Thanks in advance
Try dinosaur electronics for a cheaper board,
http://www.dinosaurelectronics.com/Onan_boards.htm
Posted on Jun 30, 2010
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
Jan 07, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty.
You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Aug 22, 2012 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
By pbarker987 on Jun 02, 2010 " " I have an onan microquiet 4000 KY. It will not start, fault code on red light indicates (35) control card failure. Before I take it to authorized onan repair is their...
Because it wont start does not indicate a control board problem It will start but it will shut down within a few seconds if it was. enail me and i will try to help you with the problem jbogilvie@hotmail.com
Jun 23, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
What dose code 48 mean on an Onan Microquiet 4000
I assume it is a ky spec j-l. It is a field sense fault. The controller is not sensing the field voltage. Check for broken wires or replace controller.
Jul 13, 2009 | Electrical Supplies
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,456 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
