Question about Continental Electric CE-AC7581 Ductless Mini Split System Air Conditioner
The air conditioner doesnt respond to the remote
I dont know if the remote is the one that doesnt work...i changed the batteries and it shows this symbols: a craked triangle and star on the lefft and high low on the right...it doesnt respond to any button and neigther does the air conditioner...what can i do? thank you.
    New Friend:
  • 9 Answers
This units ahve a reset boton on the roght side of the unit open the lid like if you was gonna change filters a small boton should be on the right side of the unit push it and if your unit turns on then you need to get a new remote if it doesn't then is your PC board
Posted on Jun 03, 2010
We have a Fujitsu split. remote ar-ry7 will turn on but unit doesnt respond. Read notes that say to reset remote. Dont know how. Wdereklewis@hotmail.com
If you look at the remote you will find a small pin hole you will have to use a pin to reset the remote just put the pin in small and push and that resets
Jun 01, 2014 | Heating & Cooling
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
Air con fan will not switch on
Hi, Is there power to the unit? Does the remote need batteries? Is the ac responding to the remote? Is it only the fan that doesnt work? More detailsplease. regards Col www.digitalcontrols.com.au
Feb 23, 2011 | Heating & Cooling
After I changed the battery of the remote the AC will not respond. I have to turn on the AC manually. T
dear sir
please turn off the switch of air con and after two minut turn on, your main electric soures for reset the settings then it will show to you on it,s display Green light. it is sign of power supply after that you can use your remote control with your air con,
hope answer the question
thank you
please vote!
Sep 25, 2010 | Fujitsu 24C1 Air Conditioner
ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Jul 20, 2010 | Sanyo Split System Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Air conditioner
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Jan 01, 2008 | Heating & Cooling
LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
Continental Electric CE-AC7581 Ductless Mini Split System Air Conditioner Logo
290 people viewed this question
Top Continental Heating & Cooling Experts
Shawn DuRee
Tim Whalen
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
