Question about EliteGroup nForce3-A Motherboard
No Lan appears
I have an ECS NFORCE3-A motherboard. i did a format to my computer ,everything ok but the ethernet adapter didn't appear on my computer . the computer didn't find it to assign its driver. .
  • 655 Answers
King,
  1. Chek out in your BIOS that the LAN is enabled or not, if there is option it must be enabled.
  2. First install your chipset driver then your on board LAN will be avail for windows. After that you can install the LAN drive
  3. Might be the driver is not for your chipset, so also varify that you have proper driver for your device and Operating system.
If any more question...just Ask me
Thanks
Iqbal
Posted on Apr 09, 2008
Asus p5g41t-m csm motherboard is having LAN problems
Go to Control Panel and Device Manager. Check Network Adapter for normal. If all appears normal go to Network and Sharing Center to setup a connection. If still unable to make a network connection then download the LAN driver for Windows 7 from ASUS at this link and install it.
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5G41T-M&os=&hashedid=FaRsjolgBLJKq49g Then reboot and try your connection again.
Dec 03, 2011 | ASUS P5G41T-M/CSM Motherboard
I don't have internet access on my new X58A-GD45 motherboard. I just tested the ethernet cable and it successfully delivered internet to another computer in my house, so it's just this new...
- check if you have a link light on the NIC port
- also check if there is a network adapter driver installed under device manager
- then click start type run and type cmd
- under CMD, type ipconfig and check if you have a valid IP
ex. 192.168.1.1 not valid is the IP that start with 169
Jun 25, 2011 | MSI X58A-GD45 LGA 1366 Intel X58 SATA...
Ethernet port dont work
First check to make sure the drivers are installed correctly you can download them easily from the msi support site. next check the bios make sure the onboard lan is enabled if everything apears correct you may want to consider purchasing an inexpensive network card from newegg.com
Sep 24, 2010 | MSI : 7030-020 Socket 754 Athlon...
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Lan problem
Dear user,,
pl log on to http://www.driverguide.com and creat your account and go to the driver tab and found driver by *********** board make and model no.
Regards,
Ravindra shah
Jun 06, 2009 | EliteGroup nForce3-A Motherboard
GeForce6100SM-M lan problem
Hi dadynidhen, there is another way to install the LAN driver & that is through windows system properties. Find the yellow question mark again & follow the instructions below.
Right click once on the yellow question mark, a window will open & Left click once on “update driver”. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Left click on the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find the folder in your system that holds the 32bit LAN driver. High-light the 32bit folder by left clicking on it once. Than click OK.
Windows will see the driver files & install the driver. Once done restart the system. Run windows update service. There may be an update for the LAN driver.
Mike
Apr 11, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Ethernet controller problem
go to device drivers and update the Ethernet drivers
Aug 07, 2008 | Intel DG31PR Motherboard
ECS GeForce6100SM-M Onboard Network Adapter does not show up in windows???
I had the same problem. Tyr this.. Install windows x64 1st install the ide driver (it's a setup program) reboot 2nd go to device manager, you will see a PCI bridge device, update that driver to the lan driver on the cd. reboot Then install the rest of the drivers. If you don't do it in that order you will NEVER be able to install the Lan driver without reinstalling windows.
Aug 11, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup nForce3-A Motherboard Logo
102 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
