Question about Electrolux Ovens
I own a creda aspire double oven,model no 48901 and we find it very difficult to regulate the heat temperature in the main oven.the fan seems to be working ok.could it possibly be the thermostat gone faulty again as we replaced same 2 years ago.please help.with thanks.jim..
5 Suggested Answers
  • 1462 Answers
SOURCE: main oven not heating up
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
Posted on Mar 29, 2007
revamos
  • 16 Answers
SOURCE: Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Posted on Apr 19, 2008
barkencoa
  • 3463 Answers
SOURCE: oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Creda Double Gas Oven. Model Europa Gas.48132.Serial No: 83 1 00087
I would contact the manufacturer and ask for the repair manual, it does not appear to be available online. Here is a link for the contact form. Hope this helps.
Jul 18, 2008 | Ovens
My c561e creda main oven(fan assited)will not heat up.everything else works
Most likely it is a blown heat element, you could check it if you have a multimeter or continuity tester.
Dec 15, 2010 | Creda Europa E010E Electric Single Oven
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Apr 19, 2008 | Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Ovens Logo
93 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
