Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Self cleaning keeps popping up beeping with F5
  • 327 Answers
Hello,the F5 beeping is all about the Push button stuck.
Check for the binding of Push button and control panel glass.If OK,replace the touch panel.
Thanks
Posted on Jun 03, 2010
  • 69 Answers
SOURCE: It won't do the self cleaning. I push the button
sumting might be stuck
Posted on Jul 11, 2009
Macmarkus
  • 2605 Answers
SOURCE: self cleaning F5
Sorry you haven't had an answer to your inquiry yet. You may not even require a remedy any longer, but in the event you do I'll post it.
The "F5" in the smw272 wall unit is indicating the on-board watchdog has detected a oven temperature sensor fault/failure. The remedy issued by Thermador's tech support and authorized technicians service manual's is to first replace the oven temperature sensor. If the display should still display after wards, replace the main relay board.
It may be too late to suggest, but you may be best served having an authorized thermador tech look at it.
Hope that helps, better late than never hopefully.
macmarkus :)
Posted on Nov 04, 2009
iwillfixforu
  • 619 Answers
SOURCE: Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Posted on Mar 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: i used the self cleaning oven and now it wont
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Posted on Oct 01, 2010
heatman101
  • 43501 Answers
SOURCE: trying to self-clean...code F5 and E1 pops
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Jan 08, 2011
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
Trying to self-clean...code F5 and E1 pops up...whats wrong?
heatman101
Jan 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to clean my oven. When I push the clean button it works for a couple minutes and then it starts beeping and an f5 code appears.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Sep 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Displays F-5 and beeping
Hello- Sorry - no good news here. The code described- F5 - indicates control board failure. The only solution is to replace the clock timer. Part is about 150$.  Installation is fairly easy, if cost is justified. These computers are the weakest link in modern ovens. If you do go with repair, avoid using the 'self-clean' function. This is the usual cause of control failure. Please acknowledge this post if informative.- Thanks-  Ed
Mar 19, 2010 | Frigidaire FEB27S5A Electric Single Oven
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
During selfceaning cycle F5 and beeping occured, removed power and powered back on and it seems to be ok, however I haven't tryed the self cleaning yet.
possibly a door latch issue depending on your brand , this is common during self clean dont self clean unless u have to those ovens get close to 1000F so melting of some parts is inevatible.. did it flash f5 and then an error code like e1 or e2 that would direct us to possible more solutions, or it might blown a thermostat more likely on a wall oven and not a range.
Jan 28, 2010 | Ovens
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
168 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
