Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printer jam...i took the back off i see no paper jamed anywhere. I removed the paper and reinstalled it still the light come on saying there is a printer jam
  • 34 Answers
To resolve this issue please do the following:
1. Open the printer access door(the gray part)
2. remove the cartridges
3. remove the printhead, to remove it press the release latch located on the upper left edge of the printhead where you put the black ink
4. Then close the printer access door WITHOUT the printhead and the cartridges.
5. unplug the printer and wait for 30 seconds and plug it back
6. it will give you a missing printhead error
7. install the printhead first, close it and then it should give an error missing cartridges. install the cartridges and if you no longer have the error upgrade the firmware by going to www.kodak.com/go/downloads
I hope that helps. If not contact kodak technical support for further troubleshooting.
Posted on Apr 09, 2008
I followed what this person said to do an it fixed my paper jam error.Thanks
Posted on Apr 12, 2009
Paper jams up goes in wrong I set it in straight and than it goes on an angle
Posted on Apr 11, 2008
Paper Jam
maybe there is more than 1 piece of paper jamed
Jun 29, 2009 | HP LaserJet 4 plus Printer
The printer had a paper jam, so I removed all the paper from that was jamed in the back compartment & now it keeps making a strange noise, it won't print & the paper jam message is still lit up. I...
hi
This can be caused by even a very small shred of paper or other debris anywhere in the printer.
Giving u a link ,plz chek tht site nd follow the instructions,hope u willl b helpfull
http://www.ehow.com/how_113761_clear-printer-paper.html
thankyou.
May 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Paper jam
The issue is with the Paper Feeder roller , either its worn out and needs an replacement.
Apr 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
Pixma mp750
it seems the lever for the paper jam is having problem you have to open the printer and check for any broken or dislodge part.
Aug 18, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Paper jam
hey, give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
I have a hp deskjet d1341 printer
take off the back cover of printer and check it out for any paper left from the paper jam and then make sure you replace the back cover properly. : )
Oct 18, 2007 | HP Deskjet D1341 InkJet Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
266 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
