Question about Linksys (PSUS4) Print Server
Schematics for seting up a printer
I have two PC in my office - PC1 has a Brother HL5340 printer hookup-ed
PC2 has no printer hook-up - Bought PSUS4 to make PC2 print to the
HL5340. Need a detailed Schematics to wire correctly
Jack Musselman
NASA ENG. Retired
  • 506 Answers
Configure and wire your systems as shown in the attached power point presentation.Schematics for seting up a printer - moz-screenshot.png 5f10200.tif
Posted on Jun 02, 2010
This printer is connected to 1 pc via usb and prints via the network from pc 2 and 3.it suddenly stopped printing from pc no 3 but still prints from pc 2
If the printer is printing from pc1 that means the usb port is ok. If prints from pc2 that means the network port is ok, so the problem is not in the printer but in PC3. Check connection of pc3 to the network, check the settings, check recently installed programs - especially firewall or new antivirus version. Scan for viruses - there are some blocking traffic. You can even turn the pc3 back in time using the system restore service.
Hope this helps.
Sep 13, 2011 | HP Laserjet M2727nf Multifunction Printer
I am running to pc's on a belkin G plus MIMO 8B09CA and my 2nd pc drops the conncetion all the time while the first runs fine and both are wired in not using the wireless setting the isp is charter com...
Have you tried swapping the cable? Use the cable connecting PC1 to the router to connect PC2 to the router, and see if the problem persists. Sometimes cable issues can cause intermittent problems.
Nov 28, 2009 | Office Equipment & Supplies
Prints same page differently on different PC's
also check the HP support link, i saw some update fix for driver and firmware for 2k3 server OS
here is the link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3662058&prodTypeId=18972&prodSeriesId=3662052&swLang=8&taskId=135&swEnvOID=1005
Apr 03, 2009 | Office Equipment & Supplies
Connecting 2 PCs to the HP PSC 1610 Printer at the same time
Hey,
This usb printer can only be connected to one pc at a time, you could use a USB SWITCH to connect both computers to the switch and printer into the other end, so with the press of a button you could connect the printer from port 1 (pc1) to port 2 (pc2)
Click here
Thanks,
Ekse
Aug 30, 2008 | HP PSC 1610 All-In-One InkJet Printer
2 Eth Cards one for Internet & one for LAN
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Apr 25, 2008 | Computers & Internet
Ef3116 has different up and down speed.
PC1 may have a defective NIC card. Also, verify that PC1's NIC card is using an up-to-date driver and that it's interface speed and duplex settings are set to auto-negotiate.
Jan 09, 2008 | Linksys EtherFast 3116 Port 10/100...
Network printing
I am afraid, PSUS4 is an older model of print server , which supports only ordinary printers. All in ones are not supported by PSUS4. Linksys have other print server which works with all in one printers. The model number is WPSM54G. Probably you can try that. Also, if the PSUS4 is less than one month old, you can get it replaced with the WPSM54G from the stores itself . The WPSM54G can be used as wired as well as wireless to the router. If you want to use the PSUS4, you may need an ordinary printer like Office jet or laser jet with USB 1.1 version.- Thank you
Oct 26, 2007 | Linksys (PSUS4) Print Server
Linksys (PSUS4) Print Server Logo
120 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
