Question about Singer 7436 - INGENUITY
Singer ingenuity, i get error 88 when i try to wind bobbin. what am i doing wrong
    Guru:
  • 351 Answers
On some of the singer machines that error means that the bobbin is in the wind position ,., I would chechk the bobbin and make sure it is in the propper position and switches like it is supposed to ..
Posted on Jun 02, 2010
I have a singer 7466 and the bobbin won't load error code 88. please help!
An 88 error code is a generic one. It could mean that the needle isn't moving properly when the machine is turned on, there could be a problem at the bobbin or the computer for the machine is compromised. When did the error occur (regular sewing or bobbin winding)?
First, make sure that the needle is at the highest point with the hand wheel. Turn the machine off and then back on. Does the needle move to the side and back to the center? If so, then the problem is elsewhere. If the needle didn't move, I'd still recommend that you clean the area under the bobbin case.
If you were winding a bobbin, try a different bobbin. Check for any burs that might block smooth rotation of the bobbin. If you were doing regular sewing, also try a new bobbin. Check the bobbin case and hook areas for lint and clean them out.
If the error still persists, the machine needs to be serviced.
I hope this helps.
Jan 18, 2017 | Singer 7466 Mechanical Sewing Machine
How do I wind a bobbin on a ingenuity
Download the instruction manual free from the Singer Sewing Machine site; it will show you how to do that.
Jun 16, 2014 | Singer 7436 - INGENUITY
Needle going up and down when winding a bobbin
if it's electronic, it sounds like the clutch has not disengaged like
it should, it might be a good idea to have the machine checked just
incase the machine may need to have some type of adjustment.
Feb 08, 2013 | Singer 7436 - INGENUITY
I can't thread my bobbin. I get a error on the number guide and it is 88. so what is wrong with it not working.
Do you have a manul for your machine?
you can download it from here http://www.singerco.com/uploads/download/467_7466_efs.pdf
I can't see anything relating to error message 88 in the manual.
So I would suggest you start by trouble shooting the bobbin case, go to page 76 in manual and folloing images, take out bobbin case, clean and replace it. Turn machine off first and once its back in turn it on and see if the 88 code has reset.
Then redo bobbin winding, and threading up. Start with the manual instructions on this page 18 and 20 and work through it step by step. Make sure bobbin is in the right way so thread is feeding off in the right direction. Also just a thought, you haven't got a stray bobbin in there that isn't a Singer one??
I hope that this helps you to eliminate your machine problem, obviously if this doesn't solve it you may need to take it for a service and see if the 88 display relates to something within the machine circuitry.
Aug 01, 2011 | Singer 7466 Mechanical Sewing Machine
I purchased a Ingenuity Singer Sewing Machine The machine will not wind a bobbin. I put the bobbin on the winder and sometimes it won?t activate when I push it to the right and other times it when it does...
Sometimes it is a simple thing like a faulty bobbin, there is a very small piece of plastic that the winder has to catch and if it is worn or broken or just plain faulty then the bobbin will not turn
Jun 17, 2010 | Singer 7436 - INGENUITY
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
My Singer 7436 keeps getting an error code 88
I have been having the same thing happen. I just discovered the bobbin winder was in the wind position. I moved it and I am in business again! Hope it works for you!
Apr 11, 2009 | Singer 7436 - INGENUITY
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
Winding bobbin thread
Did you move it to the right?It has to be against the piece above the wheel.
Aug 17, 2008 | Singer 7436 - INGENUITY
Singer 7436 - INGENUITY Logo
756 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
