Question about Kodak Cameras
The mode dial is hard to be rotated.
The mode dial is hard to be rotated. Please tell how to fix this problem?
Thanks,
Long
  • 94 Answers
You do not say what model, but it is common on the 'Z' range. The cover needs to be removed and the click spring weakend a liitle, or the dial may be worn and needs to be replaced.
Posted on Jun 02, 2010
How to replace self timer remote battery? Can't get the compartment that holds the battery, concerned that I may break it. thanks
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 26, 2011 | Olympus Camedia C-50 Zoom Digital Camera
Nikon D3100 - how to set quick response mode or delayed release so I can use remote control. Thanks
For Quick Response Mode and other Release Modes, please see "image1":
For remote control shooting or Bulb mode, see "image2":
image 2
Nov 24, 2010 | Nikon Cameras
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
Nikon D300 mirror sticks
Please check whether the mode dial is on 'Mup' or 'Lv'. If it is, then the camera is on mirror lock-up position (Mup) or LiveView mode (Lv). If any of these is selected, press the mode dial lock and rotate the dial to 'S' mode.
May 19, 2010 | Nikon D300 Body Only Digital Camera
How to use flash on a vivitar vivicam 8690
Look on the Mode Dial find a small icon looks like a camera, rotate the Mode Dial to select.Toggle the flash settings. Look on the Mode Dial and find a small icon that looks like a camera, then rotate the Mode Dial to select this setting. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Mar 17, 2010 | Cameras
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
When i take pictures on the night setting they all are blurry and distorted. why?
Try the steps below.
1. Make sure you are using the Night mode.
2. Rotate the mode dial at the top of the camera and set it to Night (it has star icon).
3. Take a picture.
Hope it works.
Thanks.
Neerak21
Sep 23, 2009 | Kodak EasyShare CX7525 Digital Camera
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Mode dial is not in the proper position
how to take good pic beside use the iso mode
May 19, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Canon PowerShot S410 - Mode Switch Problem
Your problem is fairly common. However, fixing it will require someone to actually open the camera case and clean the rotating switch (mode dial). Also, I've never personally opened an S410, but it should be similar to what's posted on the following blog using an A460's mode dial as an example. Keep in mind that there is some risk that you may actually make things worse. So remember to weigh the options before going in there. The responsibility of how things went is ultimately yours:
http://camerarepair.blogspot.com/2007/11/rear-mounted-rotating-selector-mode.html
If you decide to conduct the repair yourself, please leave a follow up comment, either here or on the blog on how things went. Good Luck!
Oct 29, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Cameras Logo
42 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
